Author Topic: New Used TD IP, advice & input needed, reseal LDA? & part# help.  (Read 10160 times)
Reply #15October 12, 2009, 03:48:30 am
Ziptar
  • 565
Re: New Used TD IP, advice & input needed, reseal LDA? & part# help.
« Reply #15 on: October 12, 2009, 03:48:30 am »
It was some what primed when I did it, i got a 2-3 inch long air bubble just below the bottle then I rigged it up, thats how I could see just a small trickle.
The return went back to the tank.
Reply #16October 17, 2009, 07:25:17 am
Ziptar
  • 565
« Reply #16 on: October 17, 2009, 07:25:17 am »
New Update:
Found the Vacuum leak. it's the throttle shaft bushing or seal, and it's huge!  >:( If it was rebuilt it was a crappy job. I couldn't narrow it down because it was so big I couldn't get it to hold a large enough vacuum long enough to find the leak. Instead I used a small bike tire pump and some soapy water to look for bubbles and that's how I found it.
The weather was supposed to be awful today (and it's not!!)  >:( and I ran out of time yesterday so slapped the old pump in one again with it's leak. I guess I'll pull it again to do the top cover seal, the upshot is I am getting to be a pro at R/R and static timing  ;) .
I guess I could be pissed at wasting the money on a junk pump but, I needed a core IP for a TD anyway, plus I got the correct hard lines and 4 rebuilt injectors, while not a total score at this point still a good deal.
Thank You everyone for your help.
« Last Edit: October 17, 2009, 07:29:59 am by Ziptar »
Reply #17October 17, 2009, 07:38:28 pm
92EcoDiesel Jetta
« Reply #17 on: October 17, 2009, 07:38:28 pm »
Good job finding the leak! In finding leaks, when soap and water is not practical, shaving cream works well.
Reply #18October 18, 2009, 07:47:32 am
Ziptar
  • 565
« Reply #18 on: October 18, 2009, 07:47:32 am »
Andrew,
Possibly, at this point that may happen, maybe I'll attempt a total rebuild.
I just want to get the leak fixed on the car for now and then possibly rebuild the TD pump as a winter project. I need to pickup a set of calipers so I can measure the shaft and busing.
I was thinking yesterday I wonder what using the Eco plunger and head would be like in the TD pump?  More HP with higher MPG?, Less HP?? or no difference especially with the new injectors. I can get a used Rabbit NA pump that "shouldn't" leak fairly cheap. Maybe put that in for the winter and make an Eco/TD Franken Pump. It would be the total opposite of what most build.
That Idea totally pointless?
Reply #19October 18, 2009, 07:58:25 am
Ziptar
  • 565
« Reply #19 on: October 18, 2009, 07:58:25 am »
Kind of pointless then.
