Author Topic: Winterization  (Read 5739 times)
Reply #15September 15, 2009, 06:02:07 am
zozep
  • 176
Re: Winterization
« Reply #15 on: September 15, 2009, 06:02:07 am »
oh i love the fan also, where did you get that from? ;)  Any boost loss from intercooler?
Actually, a 5 psi gain from adding the Intercooler.
http://www.jegs.com/c/Cooling_Electric-Fans/10117/10002/-1
Pretty sure it's the third one down, and wow is it ever quiet!!... Needed a thin fan as I wasn't sure if I'd need one on both sides for Push and Pull, but turns out the temps seem normal.
The rad incidently is for a Rabbit GTI...
« Last Edit: September 15, 2009, 06:21:45 am by zozep »
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M :(  DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
Reply #16September 15, 2009, 09:49:39 am
zozep
  • 176
Re: Winterization
« Reply #16 on: September 15, 2009, 09:49:39 am »
 ;D  WOT 2nd gear up a hill.
Reply #17September 16, 2009, 08:05:49 pm
Rabbit TD
  • 840
Re: Winterization
« Reply #17 on: September 16, 2009, 08:05:49 pm »
Damn, someting must be working good for you.  I guess your EGT gauge is right but 600 degrees with the boost that high at WOT seems ammazing to me.  But I haven't seen over 10 yet myself :-[
Reply #18September 17, 2009, 03:15:57 am
Patrick
  • 1034
Re: Winterization
« Reply #18 on: September 17, 2009, 03:15:57 am »
Did that "kit" come with the pipes? Have they got more? I'd be interested in one at that price!
Reply #19September 17, 2009, 08:58:48 am
macka
  • 957
Re: Winterization
« Reply #19 on: September 17, 2009, 08:58:48 am »
check your fuel lines for airbubbles, and check your Crank ventilation system for blockages and fouling. Is your bus bar for the glow plugs dirty? I'd just pimp out the glow plugs following the Vince Walden method. I did, no more white smoke or long startups.
Quote from: Vincent Walden
