Author Topic: *Need Help* Pump & VNt TuRBO  (Read 3380 times)
September 07, 2009, 11:34:23 am
Tiago PSS
  • 14
« on: September 07, 2009, 11:34:23 am »
Hi people,
 I´ve a question in a hibrid engine its better the 1.6 TD pump or the 1.9 aaz pump?
 Anyone have a scheme of an how put an VNT turbo working on a 16.td hibrid?
Best Regards to all,
Reply #1September 07, 2009, 01:13:14 pm
Re: *Need Help* Pump & VNt TuRBO
« Reply #1 on: September 07, 2009, 01:13:14 pm »
whats hybrid about your engine now?
and the 1.6 td pump would be better, it has a better suited LDA for fueling the VNT.
and uh, just bolt the VNT on ANY 8v VW, thats right, gas, diesel, anything, as long as it has 8 valves.
then you brew your own vain control and you are set.
Reply #2September 07, 2009, 10:16:33 pm
Baron VonZeppelin
« Reply #2 on: September 07, 2009, 10:16:33 pm »
Hello Tiago,
it sounds like you are wanting to convert a Non-Turbo 1.6 ,,,, into being a Turbocharged 1.6 engine.
Is that correct ?
If that is your plan, you will need quite a few more pieces of equipment than just the 1.6 TD Inj Pump and the VNT Turbocharger.
Can you tell us if your engine has the 11mm hex head bolts, or the 12mm triple-square head bolts ?
Reply #3September 08, 2009, 06:33:36 am
myke_w
  • 1099
« Reply #3 on: September 08, 2009, 06:33:36 am »
When I think of hybrid 1.6 td - I think 1.6td bottom end with a 1.9 AAZ head.
Is that what you mean?
If so - the 1.6td pump will work fine, 1.6 injectors will work too. You can use a VNT turbo but you'll need to figure out a way to control the vanes (usually done with IP throttle arm position).
Reply #4September 08, 2009, 09:32:56 am
« Reply #4 on: September 08, 2009, 09:32:56 am »
i know, but he was talking about putting a 1.6 head on a 1.9 to make a hybrid. i thought we talked him out of it, but maybe not. and yea, usually i think hybrid, its a 1.6 bottom end and 1.9 head.
Reply #5September 13, 2009, 04:49:04 am
Tiago PSS
  • 14
« Reply #5 on: September 13, 2009, 04:49:04 am »
Yes when i said hibrid i´m was thinking about 1.6 block & 1.9 AAZ head.
I´m putting a 1.6 pump with an Mercedes injectors.
Anyone know were i get the vaine to de vnt turbo??
Best Regards
Reply #6September 13, 2009, 10:26:35 am
« Reply #6 on: September 13, 2009, 10:26:35 am »
Best Regards
vaine to de vnt turbo? is that just some sort of non english language? and you are talkin about wanting a VNT? or taking the vaines out of it? im not quite following you.  and i would stick with some VW injector nozzles. probably just a TD pump and AAZ injectors DNSOD308? injector tips. lots of people on here swear by them.
