Author Topic: commonrail? can I swap one to work for diesel purposes?  (Read 7739 times)
Reply #30September 12, 2009, 03:59:22 pm
jack's lack
  • 275
Re: commonrail? can I swap one to work for diesel purposes?
« Reply #30 on: September 12, 2009, 03:59:22 pm »
you would probably see more of a return if you spent that money having nearly every part of the engine ceramic coated. This is a fools errand. The VE pump is beautifully simple and capable of a lot, just look at what guys like Giles do with it. If you want a CDI swap the whole thing in, I'd subscribe to that thread. Why wouldn't you start this project with a direct injection engine if efficiency and the elimination of fuel pulse is what you are interested in. At least those are set up with sensors to run ECU's, I just don't think any of us understand why you want to do this. In any design project I think it is best to start with the problem you want to address and then determine the best (cheapest, easiest, most reliable) means to achieve that goal. You have put the cart before the horse. You have started with common-rail injection and are trying to come up with a reason as to why you should use it. Start with fuel efficiency, or reliability, or torque, and then research that. It is an old VW there will be plenty of time for thinking outside the box and rigging up junkyard solutions. I know we seem like naysayers here, but you asked if it can be done and the answer is a resounding not worth it, sorry if that is not what you wanted to hear.
« Last Edit: September 12, 2009, 04:02:08 pm by jack's lack »
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #31September 14, 2009, 06:09:25 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #31 on: September 14, 2009, 06:09:25 am »
Hey! thanks for all of the input guys 8) you have been really insightful and helpful in this.  It wasn't meant to hurt anyone or their feelings.  If there is anything that I can take away from this it's perspective.  Thaks for all of the valuable input.
Kevin 8)
