Author Topic: Temporaily running a TD pump on my NA?? is it allowed?  (Read 6045 times)
August 13, 2009, 04:32:37 pm
riceatingrabbit
  • 89
« on: August 13, 2009, 04:32:37 pm »
My NA pump started leaking last week. It made the car hard to start in the mornings ( air in the system)  and got progressively worst until this morning I couldn't get it to start at all.. I killed my 800cca battery...
anyways, as I see it now I am doing a pump swap this weekend one way or another.. I have a couple of NA pumps laying around that I could put on it.
but..
I am planning on going turbo as soon as I can get my turbo rebuilt..
I am also making a trip up to the heaven of all VW diesel parts warehouses to pick up my TD geared 5 spd this weekend..
This place can also sell me a low mileage, guaranteed TD pump for $150
so...
The question is, can I run the TD pump on my car without the turbo for a while? I figure as long as theres no boost going to the LDA the pump should act like an NA pump anyways right?
am I over looking anything?
Reply #1August 13, 2009, 04:40:00 pm
saurkraut
  • 904
Re: Temporaily running a TD pump on my NA?? is it allowed?
« Reply #1 on: August 13, 2009, 04:40:00 pm »
Yes
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2August 13, 2009, 04:45:41 pm
« Reply #2 on: August 13, 2009, 04:45:41 pm »
It'll work just fine
Reply #3August 13, 2009, 05:19:54 pm
riceatingrabbit
  • 89
« Reply #3 on: August 13, 2009, 05:19:54 pm »
good to hear...
now... a question about timing...
will I time it like my NA pump?
Reply #4August 13, 2009, 05:31:43 pm
saurkraut
  • 904
« Reply #4 on: August 13, 2009, 05:31:43 pm »
Yes
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5August 13, 2009, 05:34:51 pm
jack's lack
  • 275
« Reply #5 on: August 13, 2009, 05:34:51 pm »
and go ahead and put a timing cover on it when you're finished ;)
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #6August 13, 2009, 05:47:39 pm
riceatingrabbit
  • 89
« Reply #6 on: August 13, 2009, 05:47:39 pm »
thats an old pic in the other thread btw ;)
the engine was eating timing belts due to a tweaked IP bracket... I had it off to keep an eye on the belt..
Reply #7August 13, 2009, 06:32:19 pm
maxfax
  • 2126
« Reply #7 on: August 13, 2009, 06:32:19 pm »
Hook some sort of small air pump to the LDA, smoke screen on command!!!! ;D
Reply #8August 13, 2009, 06:35:36 pm
riceatingrabbit
  • 89
« Reply #8 on: August 13, 2009, 06:35:36 pm »
I was thinking about that ;D
Reply #9August 20, 2009, 04:18:32 pm
macka
  • 957
« Reply #9 on: August 20, 2009, 04:18:32 pm »
If you can't outrun them, smoke em!
Quote from: Vincent Walden
I do know that I drive torque,  while listening to my friends prattle on about horsepower.
Reply #10August 20, 2009, 05:07:37 pm
Rabbit TD
  • 840
« Reply #10 on: August 20, 2009, 05:07:37 pm »
I'd get that pump for that price even if you didn't need it.  I really like those wheels, what size and kind are they and about what do they cost.  I'm gonna need some new tires before long and I might spring for some better looking wheels when I do.  I really like that syle.
Reply #11August 20, 2009, 06:57:58 pm
riceatingrabbit
  • 89
« Reply #11 on: August 20, 2009, 06:57:58 pm »
I ended up resealing the pump that was on the car... so far so good!!
I did get the TD pump though... But im saving it for when I get the rest of the TD stuff together..
as far as the wheels.. they are konig remembers... 15x7... running 195/50s
not sure what they cost new, i got them as part of a trade a while back. .
Reply #12August 20, 2009, 11:06:32 pm
mystery3
  • 774
« Reply #12 on: August 20, 2009, 11:06:32 pm »
Those are konig rewinds, remembers are knockoff bbs mesh style. If you want the real wheels they are compomotive minilites, you can get them in 10x13  ;D with a range of offsets.
http://www.comp.co.uk/wheels/wheels.asp?range=ML_0003
Reply #13August 21, 2009, 05:47:12 pm
Rabbit TD
  • 840
« Reply #13 on: August 21, 2009, 05:47:12 pm »
How does the little beast ride and how hard is it to turn the wheel at low speeds with them as compared to the stock ones?
« Last Edit: August 21, 2009, 05:49:12 pm by Rabbit TD »
Reply #14August 22, 2009, 10:28:36 am
« Reply #14 on: August 22, 2009, 10:28:36 am »
if you have trouble driving a rabbit with wide tires, you should not be driving. i had 205/40/ZR17's on my rabbit before, and it would steer just fine, even turning around and going under 2mph. ive had enough *** without power steering that im used to difficult steering vehicles. my rabbit steers almost as easy as if it did have power steering. no need for it, just extra weight.
