Author Topic: Anyone here promoting or running the 19:1 CR philosophy?  (Read 8306 times)
Reply #30August 14, 2009, 01:00:08 pm
gigaz2
  • 626
Re: Anyone here promoting or running the 19:1 CR philosophy?
« Reply #30 on: August 14, 2009, 01:00:08 pm »
guys... we are talking IDI's here
multiple injections? 1.9 dual spring injectors do a pre injection
it softens the noise (does it?)
multiple injections are used on CR systems, where they may be delivered at any crank angle, our VE systems are unable of that
even if they were able.. why?
Reply #31August 14, 2009, 02:03:26 pm
burnt_servo
  • 278
« Reply #31 on: August 14, 2009, 02:03:26 pm »
to the guys thinking that mulitple spray holes in a  injector is necessary  .......  you guys obviously haven't done any work with a pop tester  and a standard idi vw injector .
if everything is working properly  you get a microscopic mist  of diesel .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
