Author Topic: VE pump rebuild process  (Read 3626 times)
August 02, 2009, 06:54:16 pm
kane66
  • 131
« on: August 02, 2009, 06:54:16 pm »
I'm going to reseal my pump soon and the kit came with way more parts than I thought it would... So if figured I might as well use as many of them as possible. So I'm looking at doing a rebuild. Thought I would google  it to see what came up  found this  :o http://etc.gnarlodious.com/Vanagon/Bosch_Pump/-Rebuild.html  :o. A step by step of exactly how to rebuild a VE style pump. Lacking in a few places but worthy of a spot in the how to section.
1985 Jetta WBE
Reply #1August 04, 2009, 04:01:13 pm
janb
  • 167
Re: VE pump rebuild process
« Reply #1 on: August 04, 2009, 04:01:13 pm »
There is a Utube video VE reseal video done by a guy in Ashland, OR.  He sells for $25 on Utube, or $30 on eBay.
The Stealth Rabbit
VW-d's are forever
Reply #2August 04, 2009, 08:52:49 pm
captainpartytime
  • 39
« Reply #2 on: August 04, 2009, 08:52:49 pm »
I just used that video to reseal my n/a pump. Overall I would say it was very helpful for a first timer. It even comes with a pdf document that shows you how to make a few of the specialty sockets needed. It is a little lacking with the turbo diesel pump but if used in conjunction with Andrews well written post in the FAQ's
The Aneroid Atmospheric Bleed and What to Do If It's Leaking
you will be just fine.
-Kerry
1982 Diesel Westfalia Vanagon
1989 Wolfsburg 7-Passenger Vanagon
Reply #3January 21, 2013, 10:44:02 pm
Nevadan
  • 14
Aneroid Bleed Valve o-ring replacement link is missing
« Reply #3 on: January 21, 2013, 10:44:02 pm »
What happened to Andrew's link?  It was one of the most useful pages I've found.  Help!!!
J.D. in Reno
1985 Jetta 1.6 TD
1985 Volvo 745 2.4 TD
1987 Quantum Syncro Wagon (to receive 2.0TD)
1981 Caddy (getting 1.6 TD)
2006 Touareg V10 TDI
Reply #4January 21, 2013, 10:59:34 pm
RustyCaddy
  • 395
Re: Aneroid Bleed Valve o-ring replacement link is missing
« Reply #4 on: January 21, 2013, 10:59:34 pm »
J.D. in Reno
http://www.vwdieselparts.com/forum/viewtopic.php?f=8&t=9372&start=15&view=print
« Last Edit: January 21, 2013, 11:06:02 pm by RustyCaddy »
Reply #5January 22, 2013, 07:41:52 am
Nevadan
  • 14
« Reply #5 on: January 22, 2013, 07:41:52 am »
Perfect, thanks!
1985 Jetta 1.6 TD
