Author Topic: wheel and tire options  (Read 3014 times)
July 06, 2009, 10:58:08 am
92EcoDiesel Jetta
« on: July 06, 2009, 10:58:08 am »
Just had my wheels balanced and that took care of the steering wheel shake when going down the road. I was told the left rear tire is out of round and 2 of the (steel) rims LF & LR were slightly bent. Threads have about 75% life left but is not a matched set. The tires that are on there are 185 65R 14 on steel rims with plastic wheel covers. What are my options as far as rims and tires? I'd also like bigger diameter rear tires (if possible) for lower engine rpm.
Reply #1July 06, 2009, 11:01:29 am
rallydiesel
  • 1880
Re: wheel and tire options
« Reply #1 on: July 06, 2009, 11:01:29 am »
If you go to vwvortex you will find all the wheel possibilities you can imagine.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2July 06, 2009, 04:51:29 pm
Doakster
  • 291
« Reply #2 on: July 06, 2009, 04:51:29 pm »
I have these brand new wheels for sale if you are interested..and they are inexpensive.
http://forums.vwvortex.com/zerothread?id=4464294
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #3July 07, 2009, 03:19:48 am
Patrick
  • 1034
« Reply #3 on: July 07, 2009, 03:19:48 am »
Well..... it's front wheel drive, so you need the bigger tires on the front if at all. Biggest tire I've had on a mark 2 car was 195/60 15. No room left between the tire and the strut for anything bigger. If you really want lower rpm, you might be better off with a tranny with better gearing..........
Reply #4July 07, 2009, 06:49:31 am
GEE-BEE
  • 1604
« Reply #4 on: July 07, 2009, 06:49:31 am »
Iam running 195x 45-15 with 15 x 6 le casletts on my Mk1 caddy
Gee-Bee
Next on my list is to find a 1991 jetta 16V
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5July 09, 2009, 09:08:54 am
« Reply #5 on: July 09, 2009, 09:08:54 am »
ok, so, what are bigger rear tires going to do for a car that is FRONT WHEEL DRIVE?
Reply #6July 09, 2009, 09:23:32 am
92EcoDiesel Jetta
« Reply #6 on: July 09, 2009, 09:23:32 am »
I been driving rear wheel drive cars for a very looong time and forgot the VW is FWD.. But keep the jokes coming! :D
Reply #7July 09, 2009, 09:32:30 am
jack's lack
  • 275
« Reply #7 on: July 09, 2009, 09:32:30 am »
LOL X2
That is all they talk about over there rims coilovers and who has the lowest car. It never seems to end
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #8July 09, 2009, 12:24:16 pm
« Reply #8 on: July 09, 2009, 12:24:16 pm »
just put some 195/60/14's on it with some 14x7 wheels. it will handle like a mofo. if you like the low pro look, then go with some 205/40/17's or something. my jetta has some of those on it and i can take corners like no other...
Reply #9July 09, 2009, 12:56:45 pm
Jay
  • 157
    Derv power !
    • TONA Valet & Detailing
« Reply #9 on: July 09, 2009, 12:56:45 pm »
I've got 195/50/R15 on my Sebrings (heavy I know but they look better than the 14" steelies!)
The front have Goodyear Eagle F1's - will be going Toyo T1R's when needed.
The rear have Continental something or other.
Brilliant handling on the twisties we have round here and *touch wood* have not let me down no matter how hard I push her.
