Author Topic: Tack just stopped working  (Read 2837 times)
July 04, 2009, 10:03:54 pm
91jettaidi
« on: July 04, 2009, 10:03:54 pm »
Hey guys my tach stopped working one day and when ever i drive in the rain it some times works but i hear a squeal(like a belt)but i don't know what it is.
Reply #1July 04, 2009, 10:14:11 pm
rallydiesel
  • 1880
Re: Tack just stopped working
« Reply #1 on: July 04, 2009, 10:14:11 pm »
Sounds like you have a problem at the w terminal on your alternator. Be careful if it is loose because you could blow a bunch of stuff. My w terminal shorted against the alternator housing and blew my radio fuse, wrecked my tach and junked my alternator. Not fun.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2July 04, 2009, 10:17:41 pm
91jettaidi
« Reply #2 on: July 04, 2009, 10:17:41 pm »
so i should just tighten all the wires on my alternator
Reply #3July 04, 2009, 10:18:06 pm
  • 3255
    • My collection of HOWTOs
« Reply #3 on: July 04, 2009, 10:18:06 pm »
As well, loose alternator belt = slips when wet = makes a squealing noise = wonky tach operation.
Reply #4July 04, 2009, 10:19:48 pm
91jettaidi
« Reply #4 on: July 04, 2009, 10:19:48 pm »
ya i tightened my belt but. . .it seems only in the rain it wanted to work some times but where is that terminal on the alternator? should i take it out and clean it a bit? and retighten it.
Reply #5July 04, 2009, 11:07:29 pm
rallydiesel
  • 1880
« Reply #5 on: July 04, 2009, 11:07:29 pm »
There will be one wire going into the alternator with a quick connect joint. That is the w terminal which is what your tach uses to determine rpm. There is really no way to tighten it. Just make sure it is not contacting the actual  alternator housing. That's just one possibility of why your tach isn't working.
