Author Topic: Pictures of Turbo Possibly going bad  (Read 5169 times)
Reply #15July 06, 2009, 06:48:16 pm
Doakster
  • 291
Re: Pictures of Turbo Possibly going bad
« Reply #15 on: July 06, 2009, 06:48:16 pm »
I'd like to confirm a few things that I've read in the "checking IP pressure" thread, can you tell me if I'm on track with this.
-RPM of the pump should be checked at the drive gear, I'll be using a Laser/reflective tach to do this, RPM of the pump is 1/2 engine RPM
All RPMs I listed are pump RPMs
-IP Pressure @ 500 RPM should be 3 Bar (43.5 psi)
-IP Pressure @ 750 RPM should be 4.1 Bar (59.4 psi)
-IP Pressure @ 1000 RPM should be 5.2 Bar (75.4 psi)
-IP Pressure @ 2000 RPM should be 10.4 Bar (150 psi)
Only question that I can't seem to answer out of that thread is if it matter for a N/A, Turbo, Eco Pump
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #16July 07, 2009, 09:21:14 am
Doakster
  • 291
« Reply #16 on: July 07, 2009, 09:21:14 am »
The pressures listed are for pump rpm.  It shouldn't matter if it is a n/a, TD or ECO pump.  FWIW, I am convinced that you would actually get the best fuel economy with a larger diameter exhaust and a properly tuned TD pump.  A N/A pump would be second and an ECO pump would come in last for economy.
From what I'm reading that seems to be the consensus. I'm contemplating getting one of Giles tuned TD pumps. Any idea where I can get a 2.5in down pipe?
I assume that most MK2 2.5in exhaust systems will work due to the same body style regardless of diesel/gas.
