Author Topic: need help With water pump pulley  (Read 3155 times)
July 03, 2009, 03:45:13 pm
allsierra123
« on: July 03, 2009, 03:45:13 pm »
I just installed my new T stat and water pump housing along with the water pump. Got it on there the one thing I notice it sits out past the crank pulley a bit the old one lined up perfectly. I re used the old pulley so I know its the correct hub for the pump. Is there some sort of spacer needed or did I get the wrong water pump. Any Ideas.  I need am on a bit of a deadline need it done by monday. Maybe out of luck on that one though.
Reply #1July 03, 2009, 03:55:34 pm
92EcoDiesel Jetta
Re: need help With water pump pulley
« Reply #1 on: July 03, 2009, 03:55:34 pm »
The pulley can go on two ways. Did you try flipping it?
Reply #2July 03, 2009, 04:09:59 pm
allsierra123
« Reply #2 on: July 03, 2009, 04:09:59 pm »
I will try that. were there different sized pumps does anyone know?
Reply #3July 03, 2009, 04:14:16 pm
  • 1739
« Reply #3 on: July 03, 2009, 04:14:16 pm »
I'm pretty sure the hub can be moved on the shaft
Reply #4July 03, 2009, 04:17:27 pm
Powered by Spearco
  • 1203
« Reply #4 on: July 03, 2009, 04:17:27 pm »
Early Rabbit, up to '80 had a larger hub/flange waterpump. Then in '81, they had the smaller hub/flange waterpump. The amount of how far it stuck out was the same.
Hope this helps.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #5July 03, 2009, 04:33:39 pm
allsierra123
« Reply #5 on: July 03, 2009, 04:33:39 pm »
Yeah that helps means something isnt right and I have the correct water pump. Now how does the hub move back and forth on the shaft. I have yet to try to flip it around so It may be as simple as that But the wife said no more wrenching for today. So I will get back at it early AM tomorrow.
Reply #6July 03, 2009, 04:39:40 pm
Powered by Spearco
  • 1203
« Reply #6 on: July 03, 2009, 04:39:40 pm »
The hub on the waterpump shaft does not move in or out. It is pressed on to the shaft. Like what was said before, is the w/p pully the one for the engine and does flipping it around make a differeance?
Josh
'13 Golf R:. Tuned
'98 Puch G320
Reply #7July 03, 2009, 07:58:27 pm
allsierra123
« Reply #7 on: July 03, 2009, 07:58:27 pm »
yeah its the pulley that came off the original water pump. I will check in the morning if flipping it makes a difference. Hopefully that takes care of it. Since it doesnt move on the shaft Im not sure what else it could be.
Reply #8July 04, 2009, 05:30:58 am
lovinthedeez
  • 489
« Reply #8 on: July 04, 2009, 05:30:58 am »
I always put it on backwards the first time, it seems whenever I take mine off ::) .the side with the big indentation goes on the water pump side.  flip it over, you'll be fine.
« Last Edit: July 04, 2009, 05:40:11 am by lovinthedeez »
Reply #9July 04, 2009, 02:40:13 pm
molgrips
  • 134
« Reply #9 on: July 04, 2009, 02:40:13 pm »
+1 for flipping it round.  I did this too :)
1994 Passat 1.9 TD Estate, 180k miles, running on veg oil
Reply #10July 04, 2009, 04:56:31 pm
allsierra123
« Reply #10 on: July 04, 2009, 04:56:31 pm »
flipped it made it worse. SO I flipped it back and put it all back together a tried it. Works fine. I guess its just a little mis aligned took it down to the local german mechanics house.(he lives around the corner) he said its not far enough to worry about And the belt is tracking fine. So all is good she is running perfectly. Well that part of it anyway. Still need to figure out my ignition problem.
Reply #11July 04, 2009, 05:42:17 pm
lovinthedeez
  • 489
« Reply #11 on: July 04, 2009, 05:42:17 pm »
ignition problem......did you check to make sure your spark plugs are gapped properly? ;D
Reply #12July 04, 2009, 11:29:11 pm
allsierra123
« Reply #12 on: July 04, 2009, 11:29:11 pm »
haha well no I didnt think to. I cant start it with the key. thats a story for a different post though.
