Author Topic: EGT Install - Where to, and suggestions on a kit? Good temp to read?  (Read 6832 times)
June 24, 2009, 05:49:06 am
Pre95
  • 81
I'd like to get an EGT guage set up so I can keep an eye on my temps (this is on a 1.6 n/a but will be a 1.9T before it's all over). My questions are: Where is the best place to mount the bung for the probe? The manifold is cast and I have never been a fan of welding on cast metal. And does anyone have suggestions on a kit? I have found a Prometer setup for ~$100 (includes gauge, probe and bung) but am unsure if 'brand name quality' plays a roll here (as this seems quite cheap comparatively).
Also, once installed, what kind of temps should I expect for daily driving? What kind of temps should tell me theres an issue? Any help appreciated.
81 Rabbit Diesel - 250k and climbing :)
Reply #1June 24, 2009, 09:17:16 am
GEE-BEE
  • 1604
Re: EGT Install - Where to, and suggestions on a kit? Good temp to read?
« Reply #1 on: June 24, 2009, 09:17:16 am »
IF your going to do it:
Mcnally makes a very well made kit
Boost / EGT Temp
Complete 249.00
McNallyelectronics.com
I did all three in my center, I wanted something that was back lit with a good quality
Drill and tap the manifold , I ve seen some were you drill and clamp the probe in place
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2June 24, 2009, 03:32:55 pm
« Reply #2 on: June 24, 2009, 03:32:55 pm »
The probe part # is 10-01478.  Here's a link:
http://www.aircraftspruce.com/catalog/inpages/micro8egt.php
Here's a thread with the Westach gauges:
http://www.vwdiesel.net/forum/index.php?topic=4785.15
The round face gauge that fits a standard pod is the 2C2-1 gauge (not to be confused with the 2C2) and must be special ordered from Aircraft Spruce or directly from www.Westach.com.
Right from andrew in my message box...
Reply #3June 24, 2009, 04:57:21 pm
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: June 24, 2009, 04:57:21 pm »
Prothe's egt probe & gauge hasn't given me any issues. for $55 it's not bad. But the gauge goes to a poitnlessly high 24,000F. Nicely lit though. Prope and shielding is of decent quality.
The egt is the bightest gauge in that picture.
« Last Edit: June 24, 2009, 04:59:28 pm by Smokey Eddy »
Reply #4June 24, 2009, 10:03:15 pm
53 willys
« Reply #4 on: June 24, 2009, 10:03:15 pm »
I like isspro gauges myself....just throwing out more options..
Reply #5June 25, 2009, 12:21:36 am
Natedogg
  • 33
    • Southern Dubbers
« Reply #5 on: June 25, 2009, 12:21:36 am »
can the EGT probe not go in the downpipe just after the turbo? that was my plan. otherwise i have to remove turbo and manifold by the looks of things to tap the thread a hole for probe.
MK2 Golf GTD 'More Door' in Pasadena Blue
-75mm FK Coilovers
16" Porsche 928 Winter Wheels
223000 miles
Reply #6June 25, 2009, 05:58:54 am
« Reply #6 on: June 25, 2009, 05:58:54 am »
Placing the gauge pre-turbo right in the middle of all exhaust gasses is the best way to get the most accurate reading. Placing it post-turbo will affect the reading by I think.. ~200F? (i think that's correct anyways)
Reply #7June 25, 2009, 06:29:58 am
« Reply #7 on: June 25, 2009, 06:29:58 am »
Yeah it sucks, but because the turbo removes a variable amount of heat, based on how much it's working (ie converting heat into work), the readings downstream are also variable and render the gauge pretty much useless as a danger indicator... by the time the readings peak the damage has likely already been done.
Reply #8June 26, 2009, 09:06:16 am
Natedogg
  • 33
    • Southern Dubbers
« Reply #8 on: June 26, 2009, 09:06:16 am »
right o. glad i asked now. off come intake then. bugger.
might have to wait until i fit a bigger turbo now and leave boost alone till then.
-75mm FK Coilovers
223000 miles
Reply #9June 26, 2009, 01:14:17 pm
Pre95
  • 81
« Reply #9 on: June 26, 2009, 01:14:17 pm »
The only quarrel I have is the fact that the probe is a clamp on style (so... how do you seal it to the manifold so you dont create an exhaust leak?). Other then that the kit seems pretty straight forward. Any insight appreciated, if I could find a probe that threads in I would think it'd seal better, no?
Having a closer look, it seems it mounts to the clamp itself? Again insight appreciated..
« Last Edit: June 26, 2009, 01:16:40 pm by Pre95 »
Reply #10June 27, 2009, 12:22:02 pm
calebessent
  • 16
« Reply #10 on: June 27, 2009, 12:22:02 pm »
Has anybody found a gauge that doesn't look out of place in an old Rabbit? I'm looking for a pyrometer that looks vintage: no LEDs, glowy needles, etc.
I didn't do a search, and I'm not trying to derail this thread. I just thought I would throw my question out there while everybody was making recommendations.
Reply #11June 27, 2009, 12:58:26 pm
« Reply #11 on: June 27, 2009, 12:58:26 pm »
Here's the one I have: http://store.42draftdesigns.com/VDO-Cockpit-International-Series-1600F-EGT-Gauge_p_85.html
It can be found cheaper you'll just have to look around. The numbers are kinda stupid but I got used to 'em ;D.
