Author Topic: Is my turbine and compressor wheels too small?  (Read 19177 times)
Reply #45July 18, 2009, 12:35:40 pm
Re: Is my turbine and compressor wheels too small?
« Reply #45 on: July 18, 2009, 12:35:40 pm »
I was just thinking last night, maybe the A/R of my turbo is different than a normal one.
I saw on prothe's website in a pic of a new vnt the intake A/R was .42, mine is .48, my exhaust A/R is .65....I know nothing of what those numbers mean. I do know it changes when the boost comes on, so I's thinkin' the boost will start out of the range I ever go. I have ran it floored up to about 4300rpm and still get nothing worth mentioning.
Reply #46July 18, 2009, 12:37:46 pm
« Reply #46 on: July 18, 2009, 12:37:46 pm »
14 sounds better. but its still sick.
you should be making enough boost to grenade that engine.
should have a head shaped dent above the engine from so much boost.
Reply #47July 18, 2009, 12:39:30 pm
« Reply #47 on: July 18, 2009, 12:39:30 pm »
im pretty sure you need the right turbine ahd compressor housings to go with their respective wheels. could be wrong, but i always thought they were matched. i thought you couldnt run a .48 wheel in a .42 housing?
Reply #48July 18, 2009, 01:21:49 pm
« Reply #48 on: July 18, 2009, 01:21:49 pm »
Sorry I mustuv wrote it wrong. I meant the 14 is what I was pumping into the intake mani to check for leaks.
Not sure, I thought it had something to do with the shape/volume inside the housings, I hope somebody who knows about this pipes up. ;D
Reply #49July 19, 2009, 09:54:13 am
« Reply #49 on: July 19, 2009, 09:54:13 am »
well, thats good that your engine holds boost. at least you know your problem is turbo or intake related. too bad your rabbit wasnt better at compressing air.
