Author Topic: No start issue...  (Read 13312 times)
Reply #45June 20, 2009, 12:30:59 am
Zulfiqar
  • 254
Re: No start issue...
« Reply #45 on: June 20, 2009, 12:30:59 am »
the starter solenoid acts as a giant 300 amp relay to energise the starter - the coil in the solenoid (aka terminal 50) sucks about 40 amp on contact and stabilises at 10 amps - 40 amps on the starter switch is nasty
a bosch 70 amp relay coil only requires 0.5 amp current to energise and pass the solid 40 amp load to terminal 50 from the battery within 2 ft of wire.
Thats how Ive seen all 12V Toyota and Nissan diesels wired up from the factory
Diesel IS the future
