Author Topic: 1.5 solid 11mm head on 12mm 1.6 block?? carnage pics inside..  (Read 11897 times)
Reply #30June 10, 2009, 11:29:28 pm
maxfax
  • 2126
Re: 1.5 solid 11mm head on 12mm 1.6 block?? carnage pics inside..
« Reply #30 on: June 10, 2009, 11:29:28 pm »
Fingers crossed!!!  The suspense is killing me!!!!   :o
Ok yeah, make sure that cam sproket is tight...  ;D
Reply #31June 11, 2009, 01:01:53 pm
« Reply #31 on: June 11, 2009, 01:01:53 pm »
Here's the build thread of the Wife's car:
http://www.vwdiesel.net/forum/index.php?topic=17100.0
Also, give that cam bolt a good whack with a hammer, then re-torque it!  :)
Reply #32June 11, 2009, 03:30:01 pm
riceatingrabbit
  • 89
« Reply #32 on: June 11, 2009, 03:30:01 pm »
lol... well, last night I got it to the point that i wanted to start it.. just to hear it run, then put all of the accessory back on.....and I I got it to fire a couple times!!!!
but.. then....
the battery died!!!!
and now I am probably not going to have another chance to work on it until the beginning of next week..  so... dang!!!
oh and Brendan, thanks for the link ;D
Reply #33June 11, 2009, 04:13:26 pm
Rabbit TD
  • 840
« Reply #33 on: June 11, 2009, 04:13:26 pm »
Damn it, the suspense is killing me too :D
Reply #34June 11, 2009, 04:40:00 pm
riceatingrabbit
  • 89
« Reply #34 on: June 11, 2009, 04:40:00 pm »
... you think you guys are anxious... this is SUPPOSED to be my daily driver! I havent had a car the whole time this things been down!!! more than two months now
my fingers are seriously crossed on this thing..
what sux thought is that its so close, and now im not going to have a chance to work on it for a few days...
Reply #35June 17, 2009, 12:34:31 am
riceatingrabbit
  • 89
« Reply #35 on: June 17, 2009, 12:34:31 am »
I got a chance to work on it tonight!!!
I bled the fuel system... hit the glow plugs... crank... crank....... fire!!!! sput sput puuuurrrrrrrr.....purrrrrrr......
IT RUNS!!!!!!!
I let it run for about 45 minutes and it didnt do anything funny... so thats a good sign. I went to back it out of the garage and first is where reverse is suppose to be... so, tomorrow I have to ajust the shift linkage to be able to drive it..
I have heard that you are suppose to re torque the head after its gotten hot... thoughts on this???
proof ;D
« Last Edit: June 17, 2009, 12:36:49 am by riceatingrabbit »
Reply #36June 17, 2009, 12:50:26 am
maxfax
  • 2126
« Reply #36 on: June 17, 2009, 12:50:26 am »
Beautiful music!!!!  That's what that is!   I imagine moreso for you!
That one is 12mm right?  Did you use bolts or studs?  With studs I retorque right after warming it up to the stud maufacturer's highest spec (Arp = 85lb/ft?), then again after the 1000 miles...
I think Bentley says a quarter turn right after warmup, and another quarter turn after 1000 miles when using the stretch bolts.. Never having used the stretch bolts I can;t say for sure, but I would probably follow that procedure..
Reply #37June 17, 2009, 05:04:04 am
Zulfiqar
  • 254
« Reply #37 on: June 17, 2009, 05:04:04 am »
how come your old hydro headgasket has all similar sized coolant holes, the original goetze part Ive seen have big coolant holes on the 3 and 4 cylinders and smaller holes on the 1 and 2 cylinder side..
Diesel IS the future
Reply #38June 17, 2009, 01:47:06 pm
riceatingrabbit
  • 89
« Reply #38 on: June 17, 2009, 01:47:06 pm »
dunno... i just bought a stock mech gasket...
Reply #39June 17, 2009, 10:42:00 pm
riceatingrabbit
  • 89
« Reply #39 on: June 17, 2009, 10:42:00 pm »
oh... and a little update on the situation...
I took it out today and drove it around my neighborhood for about half an hour... it passed that test, so then I took it out on the highway....10 miles down hill, turn around and 10 miles back up that steep hill..
thats the most stressful part of my daily drive and it did it without any major issues.. coolant temp stayed right where it should be, and oil pressure looked good... I've got 35 psi at warm idle, and about 75 psi at highway speed..
the only problem I had was the small overflow coolant hose got a pin hole in it and was pissing coolant when I got it back.. and also the shift linkage is nearly unadjustable.. becuase all of the bushings are gone.. So tomorrow i will put a new hose on it and rebuild the shifter..
got about 30 miles on it now... so far so good.. keeping the fingers crossed..
Reply #40June 18, 2009, 07:37:58 am
lovinthedeez
  • 489
« Reply #40 on: June 18, 2009, 07:37:58 am »
that 5 dollar shifter bushing kit is one of the first things i replace on any old dub i come across.  good to hear it passed the test. ;D
