Author Topic: Boost Leak?  (Read 2048 times)
May 27, 2009, 06:46:12 pm
Rabbit TD
  • 840
Boost Leak?
« on: May 27, 2009, 06:46:12 pm »
I've been messing with the old original T3 which I am gonna probably try on the car this weekend.  The thing that makes me wonder is the way the wastegate operates on the pressed in cannister type ones.  I took the old canister off because it was all rusted and  not working anyway.  The question is how do these things make any boost with the valve stem having a hole drilled in it lengthwise and vented to atmosphere through the opening in the cannister.  I know it's purpose is for cooling but it looks like a major leak source to me also but I'm sure Garrett knows a lot more than me about this situation.  But wouldn't it be essentialy the same thing as drilling a hole that same size in the intake manifold as far as a boost leak or am I missing something?   I'm going to run it with just the parts needed to hold the valve shut for some comparrison testing, I did lapp the valve by the way also just to eliminate that leak  possibility.
Reply #1May 27, 2009, 06:53:10 pm
Re: Boost Leak?
« Reply #1 on: May 27, 2009, 06:53:10 pm »
There's a couple hundred cubic feet per minute of air being ingested by the engine... Really not all that much air can escape out the bleed.  Yes, it's a boost leak but it's so small it's not really going to make a difference.  The KKK turbos do the same thing btw...
Reply #2May 27, 2009, 07:02:55 pm
Rabbit TD
  • 840
Re: Boost Leak?
« Reply #2 on: May 27, 2009, 07:02:55 pm »
I figured the volume must have made up for it somehow, it just made me wonder when I tore it apart and saw how it was made a while back.
