Author Topic: Land Rover M-TDI Pump Problems!!  (Read 9102 times)
Reply #15June 20, 2009, 10:38:56 am
ryanp
  • 269
Re: Land Rover M-TDI Pump Problems!!
« Reply #15 on: June 20, 2009, 10:38:56 am »
Reuben, Is your pump a Land rover tdi? No matter what i do i can't get the pulley to line up, not even close. i have the same pulley as you too!
Did your family mention that they got the nozzles?
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #16June 20, 2009, 06:28:18 pm
blackdogvan
  • 574
« Reply #16 on: June 20, 2009, 06:28:18 pm »
All I can tell you is my set up & hope it helps... I took an AAZ pump bracket, bored it out to fit the LR pump snout, pressed on the TDI taper shaft sprocket adapter & bolted up a TDI sprocket I got from Prothe. You're not using the LR sprocket adapter by any chance?? No word from the cousins yet.
1991 Vanagon 1.9 mTDI
Reply #17June 21, 2009, 02:58:03 am
ryanp
  • 269
« Reply #17 on: June 21, 2009, 02:58:03 am »
Ahh, It looks like that is my problem!! I thought about changing the adaptor but no one mentioned it before, I'll go pick one up today!
Ryan
