glow plugs
Topic: glow plugs (Read 2889 times)
May 22, 2009, 10:29:23 am
juleshs
User+
glow plugs
May 22, 2009, 10:29:23 am »
good to be back. can anyone help me with glow plugs not heating up when i switch on the ignition, i have put in a new relay, dont know what else to check, i am running a mk3 1.9td aaz in my 90 mk2
May 22, 2009, 10:49:32 am
Re: glow plugs
May 22, 2009, 10:49:32 am »
kind of a stupid question, but are the glow plugs good? when my plugs went out, they all went out at about the same time. how bout the relay, is it getting power? if its not then check your fuseable links. how bout your fuse on the firewall? i know you probably already checked all this ***, but its worth a shot.
May 22, 2009, 10:55:11 am
juleshs
User+
Re: glow plugs
May 22, 2009, 10:55:11 am »
yes checked all . when i turn on the ignition after a short time i can hear a sort of click coming from fuse box area so i asume that is the glow plug relay switching off but plug still cold
May 22, 2009, 11:21:04 am
Re: glow plugs
May 22, 2009, 11:21:04 am »
if your relay has power coming out of it, the only thing it could be is that big fuse on the firewall, a fuseable link, or possibly (but not probable) your ground may have came off the engine. does it crank over very fast?
May 22, 2009, 11:34:24 am
juleshs
User+
Re: glow plugs
May 22, 2009, 11:34:24 am »
no it turns over as normal, i am having to use a manual switch to fire up the plugs, there is no link in the fusable link both end are joined together is ther a fuse in the fuse box to check
May 22, 2009, 12:06:24 pm
Re: glow plugs
May 22, 2009, 12:06:24 pm »
MK2 chassis generally has the glow plug fuse in a small black plastic box bolted to the firewall next to the vacuum booster in the engine compartment. A big thick red wire runs in and out.
If you've got a 1.9 in a MK2 then you've got an engine swap, however, so the wiring could all be non-stock I suppose.
glow plugs
