Author Topic: AAZ carnage  (Read 4857 times)
Reply #15May 02, 2009, 09:56:32 am
AAZ carnage
« Reply #15 on: May 02, 2009, 09:56:32 am »
yea, about that... my car smokes like a *** when its cold. and its got a cold miss starting to develop. maybe i should get a pyro..
Reply #16May 02, 2009, 11:45:18 am
AAZ carnage
« Reply #16 on: May 02, 2009, 11:45:18 am »
Quote from: "Rabbit on Roids"
just the white/grey smoke right?  my old '86 TD used to do that... i think it could have been that the valves needed adjustment.  otherwise it ran fine and gave very good mileage (over 1000km/tank)
Reply #17May 02, 2009, 11:49:03 am
AAZ carnage
« Reply #17 on: May 02, 2009, 11:49:03 am »
no, it smokes blue like a ***.
Reply #18July 19, 2009, 10:43:37 am
Re: AAZ carnage
« Reply #18 on: July 19, 2009, 10:43:37 am »
I took the engine apart today. I didn't see anything out of the ordinary... but maybe someone else's keen eye will catch something.
Pictures to follow when I get home
Reply #19July 19, 2009, 03:35:41 pm
Re: AAZ carnage
« Reply #19 on: July 19, 2009, 03:35:41 pm »
So here are the pictures.
Nothing was seized ???
This this junk on the head and pistons is related to the veg that this car ran once upon a time?
Reply #20July 19, 2009, 04:11:32 pm
lovinthedeez
  • 489
Re: AAZ carnage
« Reply #20 on: July 19, 2009, 04:11:32 pm »
man, can't imagine what kind of sounds were produced when that block came apart :o
Reply #21July 19, 2009, 06:39:18 pm
Re: AAZ carnage
« Reply #21 on: July 19, 2009, 06:39:18 pm »
Yeah that's the rod. The rest of it is in the piston below it. The pin is fine but there is that crack you can see in the piston leading to the pin. I can't move the part of the rod that is in the piston
Reply #22July 19, 2009, 06:46:29 pm
maxfax
  • 2126
Re: AAZ carnage
« Reply #22 on: July 19, 2009, 06:46:29 pm »
Kinda looks like the piece of rod in the piston is junda jammed in there agains the inside of the piston skirt?  I would have bet on the piston going to pieces before the rod if the wrist pin siezed..  Maybe just a flawed rod?
