Author Topic: Problem with head studs  (Read 5724 times)
Reply #15April 30, 2009, 06:37:27 am
53 willys
« Reply #15 on: April 30, 2009, 06:37:27 am »
Quote from: "florigolf"
. The question is, does aviation gasket sealant help or not?
it helps........forsure it helps...maybe not on a fiber gasket...but on MLS it cant hurt...
Reply #16April 30, 2009, 07:31:21 am
arb
« Reply #16 on: April 30, 2009, 07:31:21 am »
Thanks for the ideas.I will check for warpage and try a better quality gasket later. The question is, does aviation gasket sealant help or not?
If you use it, it can be a challenge to pop the head off later. The last head I had to remove (gasser) when the last guy used that great sealant, I had to take out a spark plug and pressurize the cylinder to 130 psi. Made quite the noise.
