Author Topic: Finding 130 HP on a 1.6TD - What would YOU do?  (Read 8162 times)
Reply #15April 13, 2009, 08:13:14 am
AudiVWguy
« Reply #15 on: April 13, 2009, 08:13:14 am »
The flywheel was very noticeable. Revs a lot faster. Idles great 650-700 is smooth. With less rotating mass you will see the RPM's drop faster between shifts. I used a 16V fly wheel. If you use this, make sure the TDC mark is in the exact same place. I had to use a dial indicator through the #1 cyl to remark the TDC line. So, just remember to double-check everything.
-JB
Reply #16April 14, 2009, 11:26:38 am
AdAm84
« Reply #16 on: April 14, 2009, 11:26:38 am »
This also answered my questions reguarding a lightweight flywheel. I found a 6-puck ceramic clutch with a HD 16V preassure plate and can get the flywheel as a kit for cheaper.
http://store.blackforestindustries.com/bfist2clkita.html
I think i'm gonna go with the LW flywheel after hearing that it isn't bad to drive.
Reply #17April 14, 2009, 12:33:20 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #17 on: April 14, 2009, 12:33:20 pm »
This means that your compression ratio will be a whopping 1034 PSI
 :shock: Clucking Bell!  :shock:
Reply #18April 14, 2009, 01:06:03 pm
TurboJ
  • 661
« Reply #18 on: April 14, 2009, 01:06:03 pm »
Quote from: "AndyL"
Following along with great interest; as I was about to post a similar question (though my goal was ~120hp) Only difference is I'm looking for the power down low in the RPM band.
My initial thoughts/reading were pushing me along the lines of using the 1.6 bottom end with a 1.9 head, 2.5" exhaust with a big IC - hadn't figured out the turbo yet... But then there's a problem of it does get cold here, and I'd rather the truck started in the winter - the lower compression from the 1.6/1.9 frankenmotor isn't going to help - today was going to be a day to call around and investigate if a local shop could decrease the size of the CC in a 1.9 head...
The cold starting apparently shouldn't be a problem on a healthy engine.
Definetely not enough trouble to start messing with the head.
One of the advantages of the 1.9 head is decreased compression ratio...
Jetta II 1.6 TD 'Project 200'
Reply #19April 14, 2009, 01:08:00 pm
TurboJ
  • 661
« Reply #19 on: April 14, 2009, 01:08:00 pm »
Quote from: "AudiVWguy"
-JB
I have a Passat transmission, so I need a 228 mm 'normal' style flywheel instead of the 020 wacky design.
What are the weights of stock IDI flywheels? 1.6 and 1.9?
I'm looking at either a G60 wheel or a custom piece.
