Author Topic: Bought two Garrett GT2056V turbo's Pictures added  (Read 19608 times)
Reply #15April 13, 2009, 04:35:42 pm
subsonic
  • 1836
« Reply #15 on: April 13, 2009, 04:35:42 pm »
I called the previous owner and she is checking about the insurance on this one. If it was not insured, she has a couple other different gasser turbo's I might hit her up for to make up for this one.  It really sucks this got busted up, it was in really nice shape.  I guess this might be an opportunity to look at different compressor wheels.  Anyone have any idea where I can get a replacement backing plate and wheel?
Here are the pic's:
Not sure if you can see the damage in this shot:
Reply #16April 13, 2009, 04:52:54 pm
blackdogvan
  • 574
« Reply #16 on: April 13, 2009, 04:52:54 pm »
Huge bummer.
On a side note, why does Garrrett list most VNT's as not rebuildable? I know they are but is it just a parts selling thing? Can they not control the rebuilding quality out in the world?
1991 Vanagon 1.9 mTDI
Reply #17April 13, 2009, 05:06:26 pm
subsonic
  • 1836
« Reply #17 on: April 13, 2009, 05:06:26 pm »
Quote from: "libbybapa"
Is the scroll damaged or just the backing plate and wheel?  Is the shaft bent?
It looks like it is just the backing plate and the wheel.  I can spin the shaft freely by hand and I do not notice any sort of wobble when I watch the clearance at the bottom of the wheel as it spins.  Of course thats just by eye.  It would probably need to be checked spinning with a dial guage to be exact.
Blackdogvan
"On a side note, why does Garrrett list most VNT's as not rebuildable? I know they are but is it just a parts selling thing? Can they not control the rebuilding quality out in the world?"
Beats the hell out of me.  I have seen rebuild kits for these before, so I do not know why Garrett makes such a big deal out of it.   If I can find a suitable wheel and backng plate I believe this on would be good to go again.
Reply #18April 13, 2009, 06:33:00 pm
andy2
« Reply #18 on: April 13, 2009, 06:33:00 pm »
The sprinter 2.7L 2256v has the same backing plate incase you find one of them instead.
Reply #19April 13, 2009, 07:32:33 pm
subsonic
  • 1836
« Reply #19 on: April 13, 2009, 07:32:33 pm »
I found this company on line.  I found the replacement wheel, but have not matched up the backing plate yet.  Great info on this site.  Loks like it has everything you need for vnt rebuilds.
Do you think there would be any benefit to going with a slightly smaller wheel?
http://turbo-reconditioning.com/index.php
Reply #20April 14, 2009, 06:54:56 pm
andy2
« Reply #20 on: April 14, 2009, 06:54:56 pm »
The sprinter VNTs are pretty common on eBay for fairly cheap.  Are the compressor wheels the same?
Andrew
I'm almost 100 % sure they are the same trim (exducer/inducer).The only issue is that some of the jeep turbos had thread-on compressor wheels and some had the usual nut holding the wheel on the shaft.The thread on wheel uses a different shaft that is tapered VS the non threaded one is a parallel shaft so wheels are not interchangeable!
You could turn the jeep turbo into a 2256 by installing the sprinter wheels into the jeep housings.
Reply #21April 14, 2009, 07:27:13 pm
subsonic
  • 1836
« Reply #21 on: April 14, 2009, 07:27:13 pm »
No nut on the end of the shaft on the compressor side.  Looks like it is a thread on wheel.
What did yours have Andy?
What did you end up using for a v-band clamp on the turbine housing?  How does this boost for you on your TDI?
Here are the wheel specs:
Inducer 41.5mm
Exducer 56.0mm
Trim 55
Tip width 5.5mm
Total hub length 29.3mm
No. of blades 6 / 6 split
Wheel style S / Back
Reply #22April 14, 2009, 08:34:47 pm
subsonic
  • 1836
« Reply #22 on: April 14, 2009, 08:34:47 pm »
Who knows, I may end up going that route.  I am waiting for a call back from a turbo supply shop about the parts I need for this.  I guess it will all play out to what makes better economic sense.  Is the 2256 starting to get to large to run on the vw diesel?
