Author Topic: Possible source for 1.6 and 1.9 4350 con-rods. Need info.  (Read 13525 times)
Reply #30April 08, 2009, 05:13:50 pm
truckinwagen
  • 1895
« Reply #30 on: April 08, 2009, 05:13:50 pm »
true, I think we should find out what most people want and then have them make rods just beyond that, to ensure that they wont fail if we push it a little.
83 Opel Kadett Diesel
Reply #31April 08, 2009, 05:32:41 pm
truckinwagen
  • 1895
« Reply #31 on: April 08, 2009, 05:32:41 pm »
so if we say that people are looking for 200HP, which isnt too crazy out of the ballpark, and we say they want it @ 5000RPM, which again is within the reasonable range for a hot motor, the motor will be making right around 200 ft-lbs of torque. nothing too crazy, so lets say 250 ft-lbs to be super safe.
anyone have any thoughts?
Reply #32April 08, 2009, 07:00:40 pm
rabbid79
  • 684
« Reply #32 on: April 08, 2009, 07:00:40 pm »
I think 250 ft/lb would be a bit on the low side.  With a VNT or quick spooling turbo, there could be much more torque down low.  I think 300-350 ft/lb would be more pratical.
'15 WRX
Reply #33April 08, 2009, 08:03:34 pm
Aki-76
« Reply #33 on: April 08, 2009, 08:03:34 pm »
I need conrods way over 300hv and 550-600nm torgue.
1.9na dimension, 150/24/50,6
two (big) turbos,high flow head,14mm rotorhead..pictures later  :twisted:
earlier motor push 420nm torgue,3/4 trotle...
Reply #34April 08, 2009, 08:35:07 pm
subsonic
  • 1836
« Reply #34 on: April 08, 2009, 08:35:07 pm »
The guy said he wanted to know the highest tq numbers.  He really wanted cyl pressure but since that is pretty hard to get he said he could go with tq.  He wants to make sure they dont fail, so he said to find the highest known tq number someone has put down on these rods/ or on custom rods in this application.  It would also be helpful to know the rpm range the tq number was achieved at.  I am guessing the guys in Finland may be at the top of the heap on this one.
Reply #35April 08, 2009, 09:08:26 pm
cyrus #1
  • 360
« Reply #35 on: April 08, 2009, 09:08:26 pm »
I think 250-300 ft. lbs should be sufficient for us 1.6 folk.  Shouldn't it?  I can see the 1.9 crowd wanting more strength...
Maybe it would be a good idea to start a list of who is interested.  That might serve to get the ball rolling a bit quicker.  I was kind of hoping to have my project engine together by mid summer, not be smack dab in the middle of building it.  :twisted:
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #36April 08, 2009, 10:13:58 pm
subsonic
  • 1836
« Reply #36 on: April 08, 2009, 10:13:58 pm »
Quote from: "Aki-76"
Nice to see you chime in Aki-76.  What is the most torque you have been able to get with the stock connecting rods?  Are most of your big Torque numbers from engines with 1.6 or 1.9 connecting rods?  How much torque do you think the 4350 1.6 connecting rods should be able to take?
As an additional note, I was told that tdi rods will be available soon.  I think those are very close to the 1.9td rods specs, yes?
Reply #37April 08, 2009, 10:41:39 pm
Aki-76
« Reply #37 on: April 08, 2009, 10:41:39 pm »
earlier motor is stock 1.9td ( aaz ) conrods , and put ~380nm torgue 3600-5500rpm..peak is 420nm 5300rpm..
first dyno run,with 1.6bar and very small diesel feed
http://i139.photobucket.com/albums/q302/jedi8986/sekalaiset/87780.jpg
(wheel power)
second run whit 2.2 bar litle more diesel+head gasget failure..
http://www.munkuvat.org/kuvat/93072.jpeg
(wheel power)
third (hard) run,2.6-2.65bar and full throttle.maybe 260hv and 450-470nm
This run i donīt have dynosheet
this is stock conrods,only fully balanced ( my self )
Reply #38April 09, 2009, 07:00:36 am
subsonic
  • 1836
« Reply #38 on: April 09, 2009, 07:00:36 am »
I am looking for pictures of bent / damaged connecting rods for the 1.6 and 1.9td that was due to high power output.  If you have the spec's on how it bent that is even better.  I am forwarding this onto the tech for his review.
Reply #39April 09, 2009, 09:03:57 am
« Reply #39 on: April 09, 2009, 09:03:57 am »
Quote from: "AdAm84"
Hell yeah  :D . If i had better rods there would be no reason for me to not build a crazy pump and turbo at work :twisted:  I'd deffinitly be shooting for 250hp instead.
good luck keeping your head on..
and did they say anything about a 1.5 rod? i really like my 1.5 motor, but if all i can get rods for is a 1.6, then it might be time to build a fire breathing 1.6TD.
Reply #40April 09, 2009, 04:26:51 pm
TurboJ
  • 661
« Reply #40 on: April 09, 2009, 04:26:51 pm »
1.6 rods should need to withstand at least 450-500 Nm, because 400 Nm has been broken so many times already.
So I'd say 370 lb-ft for 1.6 rods and 450 lb-ft for 1.9 rods.
Otherways they just wouldn't be a really big upgrade.
Jetta II 1.6 TD 'Project 200'
Reply #41April 09, 2009, 06:45:45 pm
andy2
« Reply #41 on: April 09, 2009, 06:45:45 pm »
As long as you have a good flowing intake manifold and only 1 fairly big non vnt turbo you should have no issues with the stock rods.I actually think that the cyl head is the limiting factor with high cylinder pressure not the rods :wink: .
Reply #42April 10, 2009, 01:27:29 pm
truckinwagen
  • 1895
« Reply #42 on: April 10, 2009, 01:27:29 pm »
well, I am working on a supercharged motor and a girdle to hold the head down better, I really want to bend some rods!
Reply #43April 22, 2009, 04:54:09 pm
monomer
  • 414
« Reply #43 on: April 22, 2009, 04:54:09 pm »
Int'l Vehicles - Many cars in the Int'l marketplace are different from US Imports. In most cases we need a sample in order to custom build a part for you.
Please fill out - Our Custom Parts Form or email us or call us at (603) 378-0090.
Available Custom Parts    Custom Parts for EVERY Vehicle
(including but not limited to)
Custom Pistons w/rings **
Custom Piston Rings
Custom Cranks (min. 5 cranks)
Custom Rods (min. 40 rods)
Custom Copperhead Gaskets
Custom Cylinder Sleeves
Custom Ground Camshafts
Custom Crank Repairs
Custom Valves
Custom Ignition Wires
Custom Pushrods
http://www.importperformanceparts.net/
they also sell topline OEM replacement rods/cranks
[/i]
www.michiganvw.org
Reply #44April 22, 2009, 08:14:19 pm
« Reply #44 on: April 22, 2009, 08:14:19 pm »
10 sets of rods? i think us off the wall build guys are kinda screwed, since most people are running 1.6 engines.
