Author Topic: any one remember this 2.1l aaz?  (Read 12759 times)
Reply #30May 23, 2009, 08:14:53 am
Re: any one remember this 2.1l aaz?
« Reply #30 on: May 23, 2009, 08:14:53 am »
SDI?
suction diesel injection. Interesting. So Naturally Aspirated? or is there more to it?
Jeeze, europe has WAY more interesting engines... why aren't they over here in boring North America? or am i just oblivious.
Here ya go.
It's for a boat, but that's a minor detail
http://www.vw-m.de/index.php?id=6&L=1
Reply #31May 23, 2009, 10:34:08 am
« Reply #31 on: May 23, 2009, 10:34:08 am »
omfg, marine VW diesels... i think ive died and gone to heaven.
now why cant we have stuff like this over here in the states.
see, this is another reason why i hate the USA. NO SWEET DIESELS!!!
Reply #32May 24, 2009, 07:36:44 pm
foxracer1
  • 991
« Reply #32 on: May 24, 2009, 07:36:44 pm »
Those are sweet. I'd run em.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #33May 24, 2009, 10:39:44 pm
DCC
  • 184
« Reply #33 on: May 24, 2009, 10:39:44 pm »
just think of how the head is setup.  5 valves per cylinder.  that is an abundance of cracks!!!  :lol: the heat stress will probably take its toll.  i bet there is much less meat between the valves etc to withstand the heat.
Those 5 valves mean lots of fresh air. I don't think the heat stress generated by the diesel engines is bigger than the 1.8 20vt itself.  :)
The heat generated by the 1.8 20vt is incredible. A friend of mine had one mounted into his '90 golf and he had to do some research to insulate the downpipe properly.. after some minutes of hard driving, the heat from the downpipe would toast the poor driver..  ;D
There are some crazy mods out there done with the stock head. If I had to do a 20v mTDI or similar I think that head would be a wise choice.
Reply #34May 25, 2009, 11:42:23 am
« Reply #34 on: May 25, 2009, 11:42:23 am »
yeah i thought gas engines ran much hotter than diesel.  wrap the down pipe in aluminum foil...  heat wrap is too expensive haha.
Reply #35May 25, 2009, 03:03:02 pm
foxracer1
  • 991
« Reply #35 on: May 25, 2009, 03:03:02 pm »
Gassers run hotter under normal driving conditions. But under full load the diesel will make more heat. And the peak cylinder pressure is alot higher on a diesel.
91 S10 305 TPI T56
