Author Topic: sporadic low compression in one cylinder  (Read 6748 times)
Reply #15July 30, 2009, 05:47:28 am
ianders
  • 10
Re: sporadic low compression in one cylinder
« Reply #15 on: July 30, 2009, 05:47:28 am »
The engine is finally purring like a kitten! Unfortunately I was distracted with many other projects, so it took me a long time. I fixed the valve, gave everything a thorough cleaning, replaced all the belts and filters and set the injection timing. The timing should be set at 1mm +- 0.02mm on this engine. I was showing 0.40mm- No wonder it was smoky. All I have left is a little more brake work and then an inspection. Thanks for the help everyone.
Reply #16July 30, 2009, 11:11:06 am
« Reply #16 on: July 30, 2009, 11:11:06 am »
Good job :D
Reply #17July 30, 2009, 03:03:48 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #17 on: July 30, 2009, 03:03:48 pm »
 ;) Happy Days
