Author Topic: DYNO RESULTS: From NA to TD 131.9 HP  (Read 11166 times)
Reply #15March 25, 2009, 10:33:40 pm
« Reply #15 on: March 25, 2009, 10:33:40 pm »
Quote from: "dubmekanik"
Not sure if this applies, but I am used to seeing air bubbles on perfectly running VW diesels through the clear feed line. I think I remember someone saying it had to do with the filter? I thought it was strange, but they assured me it didn't make much difference, as the pressure is after the pump.
It does make a difference. It is true the pressure is after the pump.. but those air bubbles are still being sucked in to the pump.. The fuel that comes out of the pump has to cycle through the injector lines and back through the return lines. Air in the system will cause "misfiring" and smoke as the bubbles affect the popping pressures of the injectors. The engines you saw were not perfectly running then :) well I guess it depends on the amount of bubbles really... one or two minuscule ones are probably expected, but big ones or frequent ones will cause side effects. It could be the filter, or it could be a connection way back at the tank that is slowly leaking in air as the pump sucks fuel through it, and air being lighter it will suck in easily.
Reply #16March 25, 2009, 10:34:44 pm
« Reply #16 on: March 25, 2009, 10:34:44 pm »
Because of the large volume of fuel being pushed thru the pump to keep it cool small air bubbles will rarely cause noticeable performance issues in the overall scheme of things... more than enough fuel will be available to the high pressure side of the pump.
Bubbles will however impact internal pump pressure on the vane pump side and therefore dynamic advance, which can cause subtle decreases in power and a potential decrease in fuel economy... my car is living proof of that at the moment.
Those little bubbles are tricky to track down... there's only so many fittings you can tighten. :roll:
Reply #17March 26, 2009, 12:00:58 am
  • 3468
    • McScrubbins Body Wash
« Reply #17 on: March 26, 2009, 12:00:58 am »
Quote from: "Vincent Waldon"
hear ye hear ye!!!
Reply #18March 26, 2009, 07:12:06 am
dubmekanik
  • 5
« Reply #18 on: March 26, 2009, 07:12:06 am »
Good discussion. The cars I spoke of had very few small bubbles every 10 sec. or so.
