Author Topic: Ok yes or no?.... Pump question.  (Read 3264 times)
Reply #15February 26, 2009, 05:27:14 am
dieselherb1
  • 354
« Reply #15 on: February 26, 2009, 05:27:14 am »
I thought this was a standard for running a TDI engine? The TDI injectors are 2 stage, needing higher pressure. I thought that was the reason to install the TDI parts into the AAZ pump?
Reply #16February 26, 2009, 07:16:54 am
Hey
  • 339
« Reply #16 on: February 26, 2009, 07:16:54 am »
The tdi engine will run with a standard AAZ camplate (I run mine with that for some time) but the injection time is longer (smooth camplate). The performance is about the same as an AAZ engine but the combustion is not as good as with an AAZ engine.
The di engines are design to have short injection burst, this is why they run much better with sharper camplate and not so good with standard idi camplate. Also the camplate is made to match the injector opening pressure
If you instal a dialgauge onto a DI pump you will see the dial moving VERY fast. For example 1 degree and it moves 0.2mm instead of only 0.1mm or something like that... injection time is shorter then!
Reply #17February 26, 2009, 08:22:14 am
foxracer1
  • 991
« Reply #17 on: February 26, 2009, 08:22:14 am »
Thanks a ton Hey. I think i'm going to just run my 1.6 plate as i have already began to put the pump back together. I'm pressed for time and just need my diesel back. I will keep all this in mind for when i begin my mTDI.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
