Author Topic: Suspected Gov problem but thinking otherwise  (Read 7495 times)
Reply #15February 05, 2009, 05:00:03 pm
« Reply #15 on: February 05, 2009, 05:00:03 pm »
Quote from: "truckinwagen"
Dremel!!!
I cant tell you the number of times my dremel has saved my ass, if you dont have one you should get one(or at least a cheap knock off)
i bought mine from princess auto for about $20, and then this kit from mastercraft for another $20 that came with a crapload of cut off discs, and all kinds of attachments.  even had a diamond cutting wheel that my dad used to cut ceramic tile.  :lol: endless uses!!!
Reply #16February 05, 2009, 06:14:55 pm
  • 3468
    • McScrubbins Body Wash
« Reply #16 on: February 05, 2009, 06:14:55 pm »
yeah i have one but no cut off wheel will ever fit down there. I went to home depot looking for a bit for it to do just that and the guy gave me a drill bit and said "this will work perfectly" and the bit broke and didn't do what i wanted it to.... What kind of bit do you think i should use? there was one there that looked like it might have worked but it said it was only for soft metals.
I think i need to go to KMS tools to find a proper bit. Carbide bits? or Cobalt bits? or Vanadium tipped bits?
I need to clean out the holes of the flange... just to clarify
Reply #17February 05, 2009, 08:06:38 pm
truckinwagen
  • 1895
« Reply #17 on: February 05, 2009, 08:06:38 pm »
get a grinding stone bit, they make long thin ones you should be able to fit into the holes and grind out the welds.
83 Opel Kadett Diesel
Reply #18February 06, 2009, 02:30:35 am
  • 3468
« Reply #18 on: February 06, 2009, 02:30:35 am »
any particular material i should look for?
Edit: I got an allum oxide one.
Oh man im angry :P when i went in yesterday i asked for dremel bits and was told there were only wood etching and tile cutting buts, no cutting/grinding dremel bits at ALL for hard metals and the guy said to use a drill bit which did nothing except cost me 10 bucks and break instantly... I went in today, made sure not to ask anyone for help, and found they had all the dremel bits i would ever want! carbide cutting bits, diamond edged bits, the list goes on. Long story short; i got the  bit and the downpipe is finally on there. Looks pretty mean :twisted:
Reply #19February 07, 2009, 03:11:56 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #19 on: February 07, 2009, 03:11:56 pm »
Weird lurching can be a knackered front engine mount. Put the hood/ bonnet up and see what the engine does as the clutch bites as you pull away, somewhere quiet obviously. If the engine flops around like dying fish there could be a problem.
Reply #20February 07, 2009, 04:49:29 pm
  • 3468
« Reply #20 on: February 07, 2009, 04:49:29 pm »
Quote from: "smutts"
That's what im thinking because at the same time i did notice that after a few pulls with the new build it did seem pretty loose in there.
Reply #21February 07, 2009, 05:35:08 pm
  • 3468
« Reply #21 on: February 07, 2009, 05:35:08 pm »
oh boy...
that mount flops like a dead fish all right.
Gggggggggooooooooddd DAMN it! I just HAD to go and break an engine mount didn't i?!!?
:twisted: YES :twisted:
