Author Topic: New Product: 1.6TD Overboost Protection Eliminator  (Read 20493 times)
February 03, 2009, 01:14:16 pm
Giles@PerformanceDiesel
  • Authorized Vendor
  • 222
    • http://www.performancediesel.ca
« on: February 03, 2009, 01:14:16 pm »
Hey Guys,
We've had a local Canadian machine shop design and build some Overboost Protection Eliminators. These will allow you to delete the factory overboost protection valve. They have been designed to use the factory clamp so no extra hardware is required. A new o-ring is included. We've matched the angles of the stock piece to allow the clamp to provide a complete seal. You will need to block off the port in the intake hose if you are using the stock intake.
They are $40 CAD. Canadians add $10 for shipping. Americans add $15 for shipping. For international orders please call or email.
(click to enlarge)
Don't limit your fun to 12psi
Giles
905-940-2266
[email protected]
Reply #1February 03, 2009, 02:39:57 pm
Dr. Diesel
  • Authorized Vendor
  • 1341
« Reply #1 on: February 03, 2009, 02:39:57 pm »
that pump looks like a jeep, rock crawling on the rubicon trail!
Reply #2February 06, 2009, 05:08:30 pm
boosted_diesel_84
  • 216
« Reply #2 on: February 06, 2009, 05:08:30 pm »
Quote from: "Dr. Diesel"
Listen up:
Internal combustion ENGINE
Electric MOTOR
Your car is powered by an ENGINE, not a MOTOR.
Then why do they Call it MOTOR OIL???????
HAHAHA, just messing with you,
Sorry To thread hijack, great product!!  would deffenitly buy, if i already didnt have a Passenger Performance 3in. Intake. which is the sh*t!!!
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #3February 06, 2009, 07:22:05 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #3 on: February 06, 2009, 07:22:05 pm »
I'm too distracted by that pristine pump to notice what this thread is about   :mrgreen:
I also love the pump head and LDA diaphragm just chillin in the picture.
I kid. Really good idea Giles. I'd be on this if it were suitable for my build.
Ed
Reply #4June 08, 2009, 10:18:44 pm
deathhare
  • 74
Re: New Product: 1.6TD Overboost Protection Eliminator
« Reply #4 on: June 08, 2009, 10:18:44 pm »
Why not just weld up the hole on the intake.  ???
Reply #5January 08, 2010, 12:45:50 am
trev0006
« Reply #5 on: January 08, 2010, 12:45:50 am »
Looks like quality stuff.
Hey Guys,
(click to enlarge)
tires cars
Giles
905-940-2266
[email protected]
Reply #6March 08, 2013, 11:15:08 am
« Reply #6 on: March 08, 2013, 11:15:08 am »
How does this work and why do I need one?
Thanks
Reply #7March 08, 2013, 11:31:08 am
« Reply #7 on: March 08, 2013, 11:31:08 am »
Thanks
The manifold has a built in 12psi popper valve. So you block the waste gate to get more boost ? the manifold will bleed the pressure in case of waste gate failure.
Reply #8March 08, 2013, 11:39:05 am
« Reply #8 on: March 08, 2013, 11:39:05 am »
Thanks, It looked like it was the 90 deg elbow on the intake with a plug in it and that didn't make any sense.
My car will pull a max of 9 now. I have thought about making a manual waste gate controller to go higher. Might I just forgo the waste gate and just use the pop off valve as a relief valve? Almost every aspect of this car has been so reliable that I have never really looked at much of it.
I keep an eye on the boost gauge anyway.
Reply #9March 08, 2013, 11:42:40 am
« Reply #9 on: March 08, 2013, 11:42:40 am »
More than likely you have a T3 or a k24 on there, and you should be alright to 15psi non-intercooled.
Reply #10March 08, 2013, 02:30:14 pm
« Reply #10 on: March 08, 2013, 02:30:14 pm »
I think I had figured it out once before but don't remember off hand.
It is the stock unit with the metal waste gate line.
Drove the car for the first time in more than a month. It was sitting down in 3" of ice.
Once free I was reminded why I like driving this car.
Reply #11January 14, 2019, 09:35:00 pm
Warnertaure
  • 7
New Product 1 6TD Overboost Protection Eliminator
« Reply #11 on: January 14, 2019, 09:35:00 pm »
Think I will order one as soon as I sell my new Sytech at ebay Ralf.
Those look to be the bomb.
Your friend does excellent work.
Whats the shipping to the US???
S-PAutomotive.com
