Author Topic: New Turbo... Should I?  (Read 7899 times)
Reply #15February 26, 2009, 08:43:52 pm
Rabbit TD
  • 840
« Reply #15 on: February 26, 2009, 08:43:52 pm »
Quote from: "jiggs"
well, after some scrapping, found some numbers on the compressor housing. 84...  is this the AR?
is it too big? will it lag too much?
i“m also intercooling the engine, on order to keep it fresh, will this bring me trouble? the turbo td04h with fmic?
btw, thanks for the inputs guys, but please do comment. :wink:
Well if the 84 is actualy the A/R of the compressor it is exactly twice as big as the stock Garrett I have from a 83 Jetta T/D {42}.  Garrett also stamped the A/R of the compressor right inside the compressor outlet also, at least back then.  I have a feeling that turbo is too big to be of much use but since you have it give it a try and let us know it turns out, that's how we all learn :D
Reply #16February 27, 2009, 01:29:59 pm
jiggs
  • 41
« Reply #16 on: February 27, 2009, 01:29:59 pm »
yeah, i guess you are right...
just waiting fo the downpipe flange to be machined and when i assemble the thingamagig i“ll let you know...
already have a T3 just in case...
more opinions?
Dark Projects...
Mecānica Auto e Performance...
