Alternator question
Topic: Alternator question (Read 3205 times)
August 04, 2005, 03:38:47 pm
leprechan
Alternator question
August 04, 2005, 03:38:47 pm »
I'm looking for a cheap and easy to find replacement, so heres the question. Will a mk2 gasser 90amp alt mount to a na 1.6 with ac? thx in advance
Nick
91' Jetta 1.6na, Monster Power!
August 06, 2005, 02:27:45 pm
leprechan
Alternator question
August 06, 2005, 02:27:45 pm »
Come on, somebody has to know.
August 06, 2005, 03:33:16 pm
Alternator question
August 06, 2005, 03:33:16 pm »
my guess is that if it would fit, there could be slight belt slippage.
August 12, 2005, 10:33:30 am
Northern RD
Alternator question
August 12, 2005, 10:33:30 am »
Quote from: "jtanguay"
That and the fact that the pulley is slightly taller, throwing off belt alignment,...
August 12, 2005, 01:51:50 pm
Patrick
Alternator question
August 12, 2005, 01:51:50 pm »
Change the pulley, probably bolt right in.
August 13, 2005, 08:22:56 am
Mark(The Miser)UK
Alternator question
August 13, 2005, 08:22:56 am »
Chances are that this gasser replacement alt will not have that magic 'W' terminal; so you'lose some facilities..gear change light, glowplug rpm based off, cruise control? easy install tacho....
Read somewhere 'W' terminal could be created by a soldered wire into circuitry?
Mark-The-Miser-UK
August 14, 2005, 04:10:28 am
Patrick
Alternator question
August 14, 2005, 04:10:28 am »
Not sure where to hook it, but it can be done. I have a GMC truck (15si delco alternator) with this mod, running a perkins in the truck. An alternator is an alternator, they all work the same.
Alternator question
