Author Topic: resurfacing 1.6 heads  (Read 6360 times)
Reply #15January 31, 2009, 05:49:57 pm
ilikevwdiesel
  • 1202
« Reply #15 on: January 31, 2009, 05:49:57 pm »
grinding the valve stem has nothing to do with refacing the gasket surface on the cylinder head. If you look at a 1.6 head, you'll see the valve face is recessed into the head about .050 or so. The main reason a machinist would grind the tip of the valve stem is to remove a burr that may have worn onto the tip from the lifter bucket rubbing against it. Valve seats tend to sink after many miles of use, there is a limit to it before they must be replaced and that would be another reason to grind the valve stem tip. If the seat is sunk and the valve is refaced, the stem may stick up too high in the lifter bore meaning you would have to install a very thin shim (in mech. lifter engines) or in a bad case not be able to set the proper clearance at all and end up with a valve that stays open all the time. As with the valve face, you can only grind so much off the tip of the stem before you interfere with the keepers, at which point the valve is junk and needs to be replaced.
My Bio
Reply #16January 31, 2009, 09:14:28 pm
Rabbit TD
  • 840
« Reply #16 on: January 31, 2009, 09:14:28 pm »
Quote from: "ilikevwdiesel"
I think you will be fine with a 2 notch if that is what was on it to begin with, if the cam spins freely it's fine.  I've had a couple heads milled and like was said earlier it has nothing to do wih piston protrusion as the head is flat anyway and as long as you can rotate the engine with no valve contact there will be no problem.  I think I would put the 11m/m studs in it though as those 11m/m headbolts don't go in the block very far at all compared to the 12m/m ones.  I'll never use headbolts again and those ARP studs screw in farther and torque so nice with none of that creaking and jerking that makes you feel uneasy wondering if something wrong just happened.  Also don't forget to retorque the head after it reaches normal temp and then cools down, especially with the fiber gasket if that is what you are using.  :D
