Author Topic: Just a couple Q's. TDI isn't my game  (Read 5280 times)
Reply #15February 01, 2009, 07:03:32 am
  • 1739
« Reply #15 on: February 01, 2009, 07:03:32 am »
Quote from: "jackbombay"
Quote from: "foxracer1"
But you would then get an intermitent code.
  FWIW, if you do the VAG-Com EGR adaptation and then eliminate the EGR system you rarely get a code, and even then it typically only happened to me at low temps, around 0*F, and high altitude, above 5,000'.
You don't even have to completely shut the EGR off completely, setting it to function at 10 % of it's cycle will cut down of the crap being pulled in and plugging everything and the check light will never come on.
