Author Topic: Vacuum Pump delete  (Read 12954 times)
Reply #30April 06, 2010, 07:54:14 am
gilligan5000
  • 63
Re: Vacuum Pump delete
« Reply #30 on: April 06, 2010, 07:54:14 am »
!UPDATE!
Well, I went ahead and hacked up the vacuum pump...
and turned this...
into this :)
the stock gear spins freely, just as it used too.  Just make sure you press out the o-ring and the bushing before you weld it shut.
Reply #31April 06, 2010, 09:00:46 am
« Reply #31 on: April 06, 2010, 09:00:46 am »
let us know how it turns out. is the shaft loose in the aluminum plug (pump base) at all?
Reply #32April 06, 2010, 10:27:33 am
gilligan5000
  • 63
« Reply #32 on: April 06, 2010, 10:27:33 am »
it spins just as it did when it was one piece.  The shaft movement is limited laterally by the brass bushing, and vertically by the gear itself.  If you want to see it in action, here you go:
randy's jetta turbo diesel first run
I have a brand new 36mm oil pump an 10w40 oil getting 5bar at starup :)
(don't mind the smoke in the vid...fresh paint just getting a burn in)
Reply #33April 06, 2010, 11:03:32 am
« Reply #33 on: April 06, 2010, 11:03:32 am »
is that the clutch slippin or the tires burnin?
Reply #34April 06, 2010, 11:59:10 am
gilligan5000
  • 63
« Reply #34 on: April 06, 2010, 11:59:10 am »
hahaha, clutch...
full details on the build here: http://forums.vwvortex.com/zerothread?id=3444483&page=1
I just wanted to update the thread for future reference here...because I love you guys :)
