Author Topic: show me pics of your k24/t3 on the 1.9  (Read 3883 times)
January 20, 2009, 06:24:44 am
Baixo
« on: January 20, 2009, 06:24:44 am »
im asking cause i am wondering what was done for the oil feed line?
any pics for referance would be greatly apreciated...
Matt
Reply #1January 20, 2009, 09:48:25 am
g-spec
  • 289
« Reply #1 on: January 20, 2009, 09:48:25 am »
My oil feed line didnt require any modification....it just bolted up to the new turbo. I have a t3 on a AAZ. Its the oil return line that does not fit. I have a custom stainless one 3/4inch ID from the turbo to the pan. Stock location is blocked.
Reply #2January 20, 2009, 10:52:09 am
« Reply #2 on: January 20, 2009, 10:52:09 am »
you can take the AAZ return line and weld it to the K24/T3 line.  you just need the banjo piece for the AAZ, and most of the return from the K24/T3.  alternatively, you might be able to use a 1.6TD pan and return it that way (with the 1.6TD return line), but i think it might be off by half an inch due to the 1.9 block being taller.
Reply #3January 20, 2009, 11:47:07 am
bert
  • 423
« Reply #3 on: January 20, 2009, 11:47:07 am »
heres mine
AAZ with T3
Bert
Reply #4January 20, 2009, 12:30:19 pm
Baixo
« Reply #4 on: January 20, 2009, 12:30:19 pm »
Quote from: "g-spec"
i gtd that im going to be swaping in a na 1.9 and using all the gtd stuff on that.
i was told about the oil feed line...i figured that i would have to do something there.
i was also told that the 1.6 oil filter housing is not transferable to the 1.9...
did you guys use the k24/t3 oil feed line on the 1.9 oil filter housing?
Reply #5January 21, 2009, 05:06:20 am
stewardc
« Reply #5 on: January 21, 2009, 05:06:20 am »
A hose making shop made me a nice new stainless braided feedline for about $30. I had just used a slightly bent 1.6 steel line before that.
Reply #6January 21, 2009, 07:43:29 pm
« Reply #6 on: January 21, 2009, 07:43:29 pm »
Quote from: "Baixo"
you nee the K24/T3 oil line fitting from the 1.6 housing.  thread that into the 1.9 filter housing.  the line feed line will fit.
