Author Topic: twin turbo  (Read 25143 times)
Reply #30January 17, 2009, 08:52:39 am
Baixo
twin turbo
« Reply #30 on: January 17, 2009, 08:52:39 am »
Quote from: "rov716y"
Quote from: "rallydiesel"
do you think a 2.25" exhaust system will be big enough to run seriose power?
I seriously doubt it.
between 150 and 200 bhp
2.25" i the biggest i can get past my rear axle.  2.5 touches the tank and axle.
i  had a mk1, and i made my own 3" exhuast....it didnt run on nothing....and we all know that mk2's, 3's, 4's, passat's....can fit 3" no problem.....
Reply #31January 17, 2009, 11:51:59 am
andy2
twin turbo
« Reply #31 on: January 17, 2009, 11:51:59 am »
Quote from: "nogama3"
Andy2, how are things going with your project?
Coming along well,We are building up an ALH TDI engine hopefully we'll have it up and running this spring.Hoping that this engine will hande the big compounds pushing 50+ psi.
Reply #32January 17, 2009, 01:33:45 pm
  • 3468
    • McScrubbins Body Wash
twin turbo
« Reply #32 on: January 17, 2009, 01:33:45 pm »
What are the key components to handling that much boost in regards to head gaskets and rings?
ARP or raceware studs?
What else?
Reply #33January 18, 2009, 04:20:03 am
Aki-76
twin turbo
« Reply #33 on: January 18, 2009, 04:20:03 am »
http://s434.photobucket.com/albums/qq68/Aki-76/pakosarjan%20sovittelua/?action=view&current=16012009237.jpg
i use my own desing bolt,extra long and super extra strong..final torgue is 130nm ( bolt hold up approximately 2200kg pull )
http://www.munkuvat.org/kuvat/73534.jpeg
Reply #34January 18, 2009, 07:52:01 am
53 willys
twin turbo
« Reply #34 on: January 18, 2009, 07:52:01 am »
Quote from: "Aki-76"
those look pretty beefy!!
I just torqued my ARP studs to 147nm!! I could not get my MLS head gasket to seal any other way..
Reply #35January 27, 2009, 06:40:37 am
nogama3
  • 162
twin turbo
« Reply #35 on: January 27, 2009, 06:40:37 am »
rov716y,
any updates regarding your project?
Reply #36January 27, 2009, 06:51:23 am
twin turbo
« Reply #36 on: January 27, 2009, 06:51:23 am »
Quote from: "Smokey Eddy"
What else?
not raceware studs... they blow  :lol:
Reply #37January 27, 2009, 07:22:39 am
foxracer1
  • 991
twin turbo
« Reply #37 on: January 27, 2009, 07:22:39 am »
The intake and turbos look good. Anymore pics of the head int/ex combo?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #38January 27, 2009, 08:38:28 am
Reply #39January 27, 2009, 09:23:03 am
rallydiesel
  • 1880
twin turbo
« Reply #39 on: January 27, 2009, 09:23:03 am »
Can you explain what you are doing with the pistons? The last one looks like an IDI piston. Is this an AAZ engine or a tdi you're making? Looks like a cool build!
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #40January 27, 2009, 09:33:25 am
Aki-76
twin turbo
« Reply #40 on: January 27, 2009, 09:33:25 am »
i take engine block 2mm off , and piston same.that piston not ready yet,i need machine guidance to air --> to chamber  ( and valve groove ).
Piston shape is very different as orginal.You see that later   :twisted:
Reply #41January 27, 2009, 12:04:26 pm
Turbinepowered
  • 1206
twin turbo
« Reply #41 on: January 27, 2009, 12:04:26 pm »
Why cut 2mm off the block? I'm just curious.
Reply #42January 27, 2009, 12:22:30 pm
arb
twin turbo
« Reply #42 on: January 27, 2009, 12:22:30 pm »
How thin will the crowns be when you cut the notches for the valve clearance ?  From what I see, your compression ratio will be the same, same stroke, just smaller displacement.
Reply #43January 28, 2009, 07:41:09 am
Gearhead
  • 87
twin turbo
« Reply #43 on: January 28, 2009, 07:41:09 am »
Aki,
You are a madman. Kudos to you for your work. Looks good.  Do you foresee any issues with that welded turbo bracket cracking as the headers heat up and expand?  I'm sure that bar will heat up as well, but not as much as the headers.  If it holds, the triangulation will make one stout header setup.
Also, looks like you're teaching that young man RIGHT!  I wish I had your shop. Kudos again.
'82 2 Door 1.6N/A :( Rabbit  '85 Cabrio project
Reply #44January 28, 2009, 08:19:38 am
twin turbo
« Reply #44 on: January 28, 2009, 08:19:38 am »
You gonna start that thing on Either?
