Author Topic: Tuning for power vs economy????  (Read 4897 times)
Reply #15January 11, 2009, 08:12:10 pm
« Reply #15 on: January 11, 2009, 08:12:10 pm »
Quote from: "Tony2ltr"
Hmmm, clattering like a powerstroke? What if I said that engine bay would be the last place I would want to be if I had a headache? It is real bad when it is cold, but quiets down a bit when it is warmed up.
-Tony
ah yes... thicker fuel develops pressure a bit earlier, and thinner fuel takes a bit more time.
viscosity does play a pretty big role in the IDI motors  :wink:
is that with the cold start cable pulled out?  idle speed boost?  at least hot idle isn't too bad...  although you want the idle to be as quiet as possible.
Reply #16January 11, 2009, 09:25:47 pm
Tony2ltr
  • 53
« Reply #16 on: January 11, 2009, 09:25:47 pm »
Well, it is quite cold here (20 degrees, but a lot of you guys are Canadian, you know about cold).
I am running about 50% homegrown biodiesel (very thick in the cold)...That is with the lever in.
-Tony
92 Jetta Ecodzl/biodzl/WVO/meth-H2O turbspray
1969 Subaru 360 Sambar (converted to Electric)
1975 Chevy Cosworth Vega Turboed
1991 Toyota Pickup (megasquirted)
2004 POS Honda Civic (I'll never buy another)
2 cylinder Lister Petter diesel CO-Gen unit
