Author Topic: fueling  (Read 6172 times)
Reply #15December 30, 2008, 11:11:15 am
fueling
« Reply #15 on: December 30, 2008, 11:11:15 am »
Did you pull the head and inspect the valves, or was this all done from the top of the engine?  If the head stayed on there's all kinds of undetected internal damage that could have happened which is preventing the engine from starting...a compression test might help determine what's going on internally.
In terms of the pump timing... you have the adjustable sprocket... so you're loosening the three smaller bolts on the sprocket and rotating the pulley until your timing pin slides into the slot at the top ?
Reply #16December 30, 2008, 11:15:12 am
96jetta
fueling
« Reply #16 on: December 30, 2008, 11:15:12 am »
ya i pulled the head completely off and left the cam and rotated it in the work bench and all the valves came down straight. thats how ive been doing the fuel pump lol just rotate it till the slot lines up with the hole. and i cant find any one with a long enough bit to pull the injectors out:(
Reply #17December 30, 2008, 12:03:50 pm
fueling
« Reply #17 on: December 30, 2008, 12:03:50 pm »
Diesels need fuel, timing, and compression.
Sounds like you have fuel and your timing is probably close enough to at least cough... compression test would be a good next step imho.
How fast was the engine running when the valves met the pistons?
Reply #18December 30, 2008, 01:20:34 pm
96jetta
fueling
« Reply #18 on: December 30, 2008, 01:20:34 pm »
about 4200 rpm  :oops:
Reply #19December 30, 2008, 02:22:08 pm
fueling
« Reply #19 on: December 30, 2008, 02:22:08 pm »
Time for a compression test my friend.
If that's up to snuff which I doubt then you need to get the correct timing tools to set the timing as required.
Reply #20December 30, 2008, 04:28:20 pm
fueling
« Reply #20 on: December 30, 2008, 04:28:20 pm »
Quote from: "zukgod1"
The good news is that the OP has an AAZ with a pre-calibrated pump and adjustable sprocket... no dial indicator required to get the timing bang on. :wink:
Reply #21December 30, 2008, 07:56:46 pm
fueling
« Reply #21 on: December 30, 2008, 07:56:46 pm »
Damn! I knew that. Have idi on the brain.
I still say he needs a compression test though.
Reply #22December 30, 2008, 10:17:22 pm
96jetta
fueling
« Reply #22 on: December 30, 2008, 10:17:22 pm »
where can i find the right bit to go into the glow plug hole? ive went to auto source and canadian tire but they only have a 12mm and 14mm bit. i need the 13mm one.
Reply #23January 03, 2009, 03:19:03 pm
96jetta
fueling
« Reply #23 on: January 03, 2009, 03:19:03 pm »
ive got 300psi in the #1,310psi in the #2, 300psi in the #3, 315psi in the #4
Reply #24January 03, 2009, 03:23:11 pm
  • 3468
    • McScrubbins Body Wash
fueling
« Reply #24 on: January 03, 2009, 03:23:11 pm »
Quote from: "96jetta"
How did you get the tester into the GP hole?
Reply #25January 03, 2009, 03:38:01 pm
fueling
« Reply #25 on: January 03, 2009, 03:38:01 pm »
You'll be lucky if it starts with those numbers in anything below 0 C.
Reply #26January 04, 2009, 07:33:49 am
96jetta
fueling
« Reply #26 on: January 04, 2009, 07:33:49 am »
i didnt i pulled all of the injectors and did it from there. butthe compression tester only hits 300psi again i couldnt find anything. so for all i know its above
Reply #27January 05, 2009, 03:33:09 am
Mark(The Miser)UK
  • 1557
fueling
« Reply #27 on: January 05, 2009, 03:33:09 am »
Quote from: "burn_your_money"
The readings are all so similar, that I'd be inclined to say that the gauge may be reading low. I have a snap-on gauge, which I believe is correct, however my adaptors are made up. First readings on my car were all 160psi. I've now filled more space up inside the injector body I used and they are all over 300psi. Car starts at -5 C. I had most of the internals to the injector [only lower half used], yet had to add washers etc to remove that 1cc. I my fill with lead and drill a pilot hole.
Mark-The-Miser-UK
Reply #28January 05, 2009, 09:33:22 am
fueling
« Reply #28 on: January 05, 2009, 09:33:22 am »
Are you saying the dial on your compression tester only reads up to 300 psi ??
