Author Topic: best winter snow tires?  (Read 9312 times)
Reply #15November 19, 2008, 08:47:34 pm
Dakotakid
  • 1240
« Reply #15 on: November 19, 2008, 08:47:34 pm »
Banned studs because of what??? ....increased highway wear???? Or do they own the body shops?!?!?
Reply #16November 20, 2008, 02:28:38 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #16 on: November 20, 2008, 02:28:38 am »
From the Ontario Highway Traffic Act:
9.  (1)  No person shall operate a vehicle equipped with studded tires on a highway unless all of the following conditions are met:
1. The vehicle is operated during the period starting on October 1 and ending on April 30.
2. The permit holder of the vehicle is,
i. a resident of Northern Ontario,
ii. a corporation with a business premise in Northern Ontario, as shown by the address on the plate portion of the vehicle permit,
iii. a municipal corporation having jurisdiction and control of a highway or portion of a highway located in Northern Ontario,
iv. a road authority having jurisdiction and control of a highway or portion of a highway located in Northern Ontario,
v. a district school board in Northern Ontario,
vi. a school authority in Northern Ontario,
vii. Her Majesty the Queen in right of Ontario, or
viii. not a resident of Ontario and the vehicle is in Ontario for no longer than 30 days.
3. In the case of a vehicle with a gross vehicle weight rating equal to or less than 3,500 kilograms, all vehicle wheels are equipped with studded tires.
4. In the case of a vehicle with a gross vehicle weight rating greater than 3,500 kilograms, studded tires are either on all vehicle wheels or on only the vehicle wheels on one axle, and the vehicle is,
i. an ambulance, police vehicle or fire department vehicle,
ii. a school bus,
iii. a public utility emergency vehicle, or
iv. a road service vehicle as defined in section 133 of the Act.
5. The studs meet the specifications listed in paragraph i or ii as follows:
i. The studs,
A. are evenly embedded during tread manufacture,
B. do not protrude more than 2.0 millimetres,
C. have an aggregate object exposed surface area of 3 per cent of the tread surface area or less, and
D. have an exposed surface area variability between tires of the same size of no greater than 25 per cent.
ii. The studs,
A. are securely and safely embedded after tread manufacture in pin-holes moulded in any part of the tread other than the middle one-third,
B. are inserted in a tire that after manufacturing or remoulding has never been driven on a vehicle,
C. have only one peak per stud and no hollow part, and
D. meet the stud specifications applicable to the gross vehicle weight rating of the vehicle on which the studded tires are mounted, as set out in the Table.
TABLE: STUD SPECIFICATIONS
Note: the table didn't reproduce properly, but no steel or hollow studs are allowed for vehicles under 3500 pounds.
Calvin
91 VW Golf 1.6NA 5spd
Reply #17November 20, 2008, 02:07:33 pm
Patrick
  • 1034
« Reply #17 on: November 20, 2008, 02:07:33 pm »
Quote from: "Dakotakid"
The law was passed a while ago, studs used to do a pile of damage to teh roads around here. Technology has changed though, the new stuff does a lot less damage. I've thought long and hard about studding up anyway.............
Reply #18November 24, 2008, 12:02:51 pm
Slave2School
  • 531
« Reply #18 on: November 24, 2008, 12:02:51 pm »
I've always had good luck with green diamond tires when I could find them.  This year I've got Nokian WR-G2 tires.  They seem great so far but we havn't had a major dumping yet.
2002 ford focme wagon
Reply #19November 24, 2008, 06:32:40 pm
EcoMod
  • 44
« Reply #19 on: November 24, 2008, 06:32:40 pm »
I even used these for a track day @VIR
Tires and wheels, shipped, mounted and balanced for 300.00 Discount tire
1992 Jetta EcoDiesel (red)
2001 7.3L Excursion
1993 VR6 5spd B3 Wagon
Reply #20November 24, 2008, 06:58:37 pm
blkboostedtruck
  • 1535
« Reply #20 on: November 24, 2008, 06:58:37 pm »
Quote from: "EcoMod"
really those rim too? those would fit a rabbit too! you gotta link to them?
and do they have studs that can be installed at that place if one wants them?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #21November 24, 2008, 07:28:02 pm
EcoMod
  • 44
« Reply #21 on: November 24, 2008, 07:28:02 pm »
http://www.discounttiredirect.com/direct/reviewOrder.do?zc=22911&x=67&y=6
I got them last year on a special sale. Looks as if they are now $424.00 mounted, balanced, and shipped to your door. :wink:
I also had them on a old corolla that I had setup for rally, the tires made it perform awesome in the slushy, mountain roads while using the ebrake to steer...haha
2001 7.3L Excursion
