Author Topic: what do ya think about this breather box?  (Read 8943 times)
Reply #15November 14, 2008, 03:32:37 pm
« Reply #15 on: November 14, 2008, 03:32:37 pm »
One could prob just tap the front of the pan for the return maybe?
Reply #16November 14, 2008, 03:56:50 pm
blkboostedtruck
  • 1535
« Reply #16 on: November 14, 2008, 03:56:50 pm »
Quote from: "zukgod1"
you wouldn't need to! there a perfect spot on the front of the block!
early rabbits that had the hose for the vac pump and a small plate bolted to the block with a hose attachment for it! later it was just blocked off with a plate because the vane pumps i guess did not need an exit? so it would be easy to drill and tap that plate! easier then doing the oil pan? even easier just get an older style that had a place to attach a hose!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #17November 14, 2008, 05:07:54 pm
Green79
  • 27
« Reply #17 on: November 14, 2008, 05:07:54 pm »
'79 1.5 Rabbit
Reply #18November 14, 2008, 05:14:03 pm
« Reply #18 on: November 14, 2008, 05:14:03 pm »
You guys ever seen what the filtered oil in the CCV filters looks like? I wouldn't want it back in my enigne.
Reply #19November 14, 2008, 05:18:05 pm
53 willys
« Reply #19 on: November 14, 2008, 05:18:05 pm »
Quote from: "burn_your_money"
You guys ever seen what the filtered oil in the CCV filters looks like? I wouldn't want it back in my engine.
thats what I was gonna say too!! yuk! maybe if you filtered it some how? I would rather drain the crap out every now and then.
Reply #20November 15, 2008, 03:52:00 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #20 on: November 15, 2008, 03:52:00 am »
Quote from: "blkboostedtruck"
both those link just show main page and not the item!
Duane
Actually, the links work but that site forces you to enter a zip code before you can see what the link is for.  The box for zip code is near the top at the center.  Enter your zip code and you can see the part.
Calvin
91 VW Golf 1.6NA 5spd
Reply #21November 18, 2008, 08:38:19 pm
blkboostedtruck
  • 1535
« Reply #21 on: November 18, 2008, 08:38:19 pm »
well i bought that breather ! should work good?
Duane
'66 variant 1500S
