Author Topic: t3 turbo off a volvo 740, will it work on a aaz  (Read 5215 times)
Reply #15November 14, 2008, 11:31:03 am
paddy_ireland
  • 9
« Reply #15 on: November 14, 2008, 11:31:03 am »
so where can i get a msl and arp's?
when you say exhaust port enlargened will i need a new ex manifold to go with it?
mk2 man all the way
Reply #16November 14, 2008, 11:53:04 am
rallydiesel
  • 1880
« Reply #16 on: November 14, 2008, 11:53:04 am »
Quote from: "paddy_ireland"
I don't know where you're at but the gasket can be ordered from
http://www.importcarpartscanada.ca/index.wws
although I can't say 100% it won't be fibre although the one I got was MLS.
The exhaust ports just need to be matched to whatever manifold you're using and then enlarged within the head. The intake ports don't really need to be enlarged but should be matched to the manifold as well.[/img]
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #17November 14, 2008, 12:00:03 pm
paddy_ireland
  • 9
« Reply #17 on: November 14, 2008, 12:00:03 pm »
and its deffo not able to be done on a standard set up? standard manifold like....or will this cause something to blow up at around 150 bhp?
pics to follow later on the turbo
mk2 man all the way
Reply #18November 14, 2008, 02:18:45 pm
TurboJ
  • 661
« Reply #18 on: November 14, 2008, 02:18:45 pm »
You referring to inlet or exhaust manifold now?
Inlet manifold as standard has one major flaw - it has enough flow for most people's needs, but it does nothing to help divide the airflow evenly accross all cylinders. If you look at any racing cars or well built street turbo cars, this will always be one key concern when designing manifolds. Not only does even airflow improve power, but crucially, it makes a big difference to reliability.
Exhaust manifold as it is on a 1.6 TD or 1.9 TD, is not the worst there is, but after 150 hp or so it will become a bottle neck. Of course, many people end up ditching it for a different reason, namely for the very rare turbo flange that won't allow many turbo upgrade options without adapter flanges, which can be tricky. BTW, good cast turbo manifolds with either T3 or T25 flange can be had for $150 on eBay.
Jetta II 1.6 TD 'Project 200'
Reply #19November 14, 2008, 03:52:01 pm
rallydiesel
  • 1880
« Reply #19 on: November 14, 2008, 03:52:01 pm »
Like this?
Reply #20November 15, 2008, 09:34:28 am
TurboJ
  • 661
« Reply #20 on: November 15, 2008, 09:34:28 am »
Yes. Those things are really not that bad even though you can get them pretty cheaply.
Reply #21November 15, 2008, 02:15:53 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #21 on: November 15, 2008, 02:15:53 pm »
i think i'll get one for my 1.6TD project car - then stick a t3/t4 on it :evil:
'91 Golf Cabrio 1.9TD
