Author Topic: 1.6 Crank Trust Bearing Woes  (Read 5715 times)
Reply #15November 14, 2008, 01:52:10 pm
monomer
  • 414
« Reply #15 on: November 14, 2008, 01:52:10 pm »
Quote from: "zukgod1"
I'm pretty sure that's just supose to be a flat surface. no groves at all.
I cant do "pretty sure"
I need a straight answer...
www.michiganvw.org
Reply #16November 14, 2008, 02:18:22 pm
Black Smokin' Diesel
  • 656
« Reply #16 on: November 14, 2008, 02:18:22 pm »
The spare crank I have here has no such groove. It came from a 1.6TD manual tranny.
Reply #17November 14, 2008, 02:36:14 pm
monomer
  • 414
« Reply #17 on: November 14, 2008, 02:36:14 pm »
Quote from: "Black Smokin' Diesel"
I'd take that "spare" off your hands but international shipping on a 35lb item would kill.
anyone have one laying around. HAS TO BE A MANUAL!
www.michiganvw.org
Reply #18November 14, 2008, 03:10:19 pm
« Reply #18 on: November 14, 2008, 03:10:19 pm »
Quote from: "monomer"
I'm pretty sure that's just suppose to be a flat surface. no groves at all.
Ok. It's NOT suppose to have a grove.
Flat surface.
Reply #19November 25, 2008, 09:35:49 am
arb
« Reply #19 on: November 25, 2008, 09:35:49 am »
The flat needs to be flat. That said, how does the thrust bearing look? The grove looks uniform and there is at least 50% of your area that looks good. If you have another crank, use it. In not, and the bearing looks good except for the grove, and your money is low, use it.
Reply #20November 25, 2008, 01:05:18 pm
monomer
  • 414
« Reply #20 on: November 25, 2008, 01:05:18 pm »
Quote from: "arb"
Bearing is MIA.
I cleaned garage....
New crank and new glyco bearing will be used. I've spared no expense thus far in the build; I'm sure as hell not going to here.
www.michiganvw.org
