Author Topic: ARGH! Why does my ****ing battery keep going flat?  (Read 8499 times)
Reply #15November 01, 2008, 05:54:26 pm
dillenger1
  • 777
« Reply #15 on: November 01, 2008, 05:54:26 pm »
Try isolating the starter.Mine is behaving the same,It turned to be the starter.I even took it apart ,cleaned and degunked everything,no change.Check for post insulation or lack there of.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #16November 01, 2008, 06:04:47 pm
« Reply #16 on: November 01, 2008, 06:04:47 pm »
Quote from: "shegel"
my golf had a bad diode for as long as i have owned it .....about 2 years. and i never had the battery drain on me. i dont think its the diodes
Diodes can fail open... in which case they generally cause no symptoms other than a decrease in the available output power of the alternator.
They can also fail closed... in which case they will usually drain the battery by causing a direct path for current thru a field winding.
Reply #17November 02, 2008, 01:20:13 pm
molgrips
  • 134
« Reply #17 on: November 02, 2008, 01:20:13 pm »
Every couple of hours of driving, roughly, the tach goes a bit crazy for 5 minutes and then returns to normal. It's the alternator, cos if it comes back in when I'm idling and the fan/lights are on I can hear the engine note dip.
Stereo is a basic small one, nothing fancy.
Something else I noticed today - the central locking keeps making that noise it makes for a few minutes after I lock the car, but I heard it again today a good three hours after driving it last.  This could be the problem.
1994 Passat 1.9 TD Estate, 180k miles, running on veg oil
Reply #18November 02, 2008, 01:33:30 pm
  • 1739
« Reply #18 on: November 02, 2008, 01:33:30 pm »
___________
Very possible. I had a golf that, because the central locking had a leak, and didn't lock the trunk, the customer didn't know the truck wasn't locked, and lo- dead battery. The vacuum/pressure pump for the central lock has a function that shuts it after a 30 secs. if it's still running. however it sounds like yours isn't working as it should.
Reply #19November 08, 2008, 08:55:49 pm
handedyourhat
  • 33
trunk light
« Reply #19 on: November 08, 2008, 08:55:49 pm »
I had a problem with my trunk light staying on it took about 1 day of charging the battery back up to full charge and the battery would die again, I removed the altanator from the system and I still had quite a large arc at the batt terminal  :shock:  so I got a thinkin, I replaced my trunk lid a week before and had no idea how the inside trunk light turns on and off , I still dont !!!, so I removed the light bulb from its holder and I haven't had a problem since :lol:  :lol:  :lol:
Most of the time I get sooo far ahead of myself that I have to stop and let myself catch up......
87 jetta 1.6L TD project
87 jetta 1.6L TD Daily  (new 1.6, Giles,3", inner cooled. Home made fuel...
95 jetta 1.9L TD project
94 golf TD new edition to my family (LOL)
Reply #20November 09, 2008, 12:51:05 am
  • 3468
    • McScrubbins Body Wash
« Reply #20 on: November 09, 2008, 12:51:05 am »
Wow. I'm happy for you but what a head ache! You won't forget to check that ever again next time you're having batt troubles. Takes two seconds to check but, obviously, easily overlooked.
Reply #21November 27, 2008, 04:34:09 am
rubadubdub
  • 109
« Reply #21 on: November 27, 2008, 04:34:09 am »
Given the fact your tach goes mad the following is unlikely but just something else to consider if all else fails...
My dad had a problem with his mondeo battery occasionally discharging.  I traced it to a leaking rear light which would fill the boot up with water only when the car was parked bonnet downhill whilst it was raining, which created the short which drained the battery.
My reason for mentioning it was you said you've tested and couldn't find a constant drain on the battery.  However if you have electrical circuits which are getting wet occasionally the drain may not always be there.
1991 Mk2 Golf GTD
Reply #22November 27, 2008, 10:43:49 am
  • 3468
« Reply #22 on: November 27, 2008, 10:43:49 am »
Quote from: "rubadubdub"
That doesn't sound very unlikely to me! that's good advice. These lights do leak frequently when they age a little.
Reply #23December 24, 2008, 03:59:43 am
molgrips
  • 134
« Reply #23 on: December 24, 2008, 03:59:43 am »
Hmm.. interesting.. it does seem intermittent. I will keep an eye on when it happens next.
