Author Topic: Oil pressure  (Read 4979 times)
Reply #15October 31, 2008, 07:29:40 am
Oil pressure
« Reply #15 on: October 31, 2008, 07:29:40 am »
O-ring is all.. Loosen the bolt holding the dipstick and push down on the tube and tighten at the same time to put some pressure on the o ring.
I agree though, you probably had some venting issues..
Reply #16October 31, 2008, 12:33:02 pm
Jet A
  • 125
Oil pressure
« Reply #16 on: October 31, 2008, 12:33:02 pm »
Quote from: "53 willys"
what plugs the hole on the dipstick tube?? (block side)....I got a rubber oring and a copper washer....mine started to leak today...I think its cause I was experimenting with some crank case venting...
I'm just wondering what is factory to seal the oil dipstick tube??
my old engine never had anything on it when I pulled it apart...
JB weld..... :oops:
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #17October 31, 2008, 12:44:29 pm
Oil pressure
« Reply #17 on: October 31, 2008, 12:44:29 pm »
Quote from: "Jet A"
JB weld..... :oops:
 :lol:  :twisted:  :lol:  :twisted:
JB weld is your friend..
Reply #18October 31, 2008, 01:19:11 pm
Oil pressure
« Reply #18 on: October 31, 2008, 01:19:11 pm »
I got 50psi@head hot. My bentley only says min 28psi@2000rpm I get about 35psi @hot 2000rpm. Not sure 'bout idle.
