Author Topic: TDI Baja Racer  (Read 10389 times)
Reply #15October 25, 2008, 08:34:04 am
Greasecar
  • 126
    • http://www.greasecar.com
TDI Baja Racer
« Reply #15 on: October 25, 2008, 08:34:04 am »
Thanks again for the help Tintin, I hope to make some time on Sunday to dig into the harness again.
We are basically running a Greasecar conversion kit but had to modify a few things for the SCORE rules and safety regulations. The main difference from a standard kit is the fuel tank is an FIA certified bladder race cell that we added a heated fuel pickup to.  The heated filter, valves and wiring are standard Greasecar. We are using a small 6 gal cell for diesel startup.
Tis years race is just over 600 miles (last year was over 1300), unfortunately there won't be much time for testing as we likely won't have the car complete until the first week of Nov. and the race starts the 20th.  The primary hurtle right now is this wiring issue which seems totally bizarre, it is such a simple circuit, I cant image what could possibly be wrong.
www.greasecar.com
79 Mini diesel (1.5 Peugeot)
82 rabbit TD (given to Junkcollector Jay)
84 rabbit TD (intercooled w/ VNT)
82 rabbit PD (undergoing swap)
01 Golf TDI (burned to the ground)
02 Golf TDI (355,000 miles and counting)
04 Passat TDI Wagon (Grocery getter)
Reply #16October 26, 2008, 06:12:46 am
fairweather
  • 85
    • TDI Syncro
TDI Baja Racer
« Reply #16 on: October 26, 2008, 06:12:46 am »
I looked on your site but didn't find what kind of TDI it is? Is it  1Z or ?? Also, you say that you used an adapter plate, is that a KEP or custom? What clutch disc and PP are you using? Are these all trade secrets:-)?
Good Luck!
Tom
83 Caddy with CY code 1.6TD out of a rabbit.
Reply #17October 26, 2008, 06:32:16 am
jimbote
  • 168
TDI Baja Racer
« Reply #17 on: October 26, 2008, 06:32:16 am »
possibly bad QA?....
Reply #18October 27, 2008, 11:15:31 am
Greasecar
  • 126
TDI Baja Racer
« Reply #18 on: October 27, 2008, 11:15:31 am »
The engine is an ALH with KEP adaptor, the clutch is a 4-puck off-road racing clutch not sure of make or specs.
According to my schematics the Throttle pedal terminals are as such and the voltages that I measured are as follows:
TPS
1- resistor                       measured output:(.7-00vdc)
2- 5v power from ECU      measured output: 5vdc
3- reostat                        measured output(00-00vdc)
Kick-down
5-                                   measured output:(.10-7.35vdc)
Closed Throttle Position
4-                                   measured ooutput:(.42-4.32vdc)
6- ground                        has been separated from MAP circuit and grounded to batt to eliminate fault code.
I have been able to get rid of all of my codes but the TPS still gives no signal to the ECU or VAG-com
www.greasecar.com
Reply #19October 27, 2008, 02:38:31 pm
fairweather
  • 85
    • TDI Syncro
TDI Baja Racer
« Reply #19 on: October 27, 2008, 02:38:31 pm »
You might try asking this guy:
David Marshall  http://hasenwerk.ca
He is a member of the TDI vanagon group and is quite knowledgeable. Wiring/ECU issues come up quite often when installing the TDI in a non-stock situation.
http://autos.groups.yahoo.com/group/TDI-conversion/
Might be worth a look.
