Author Topic: question about my turbo  (Read 3926 times)
Reply #15October 21, 2008, 10:04:56 am
MouseGTD
  • 110
« Reply #15 on: October 21, 2008, 10:04:56 am »
how would i go about putting a relay into the circuit? and would i have to use a specific type of relay?
Reply #16October 21, 2008, 12:53:35 pm
« Reply #16 on: October 21, 2008, 12:53:35 pm »
yea the sensor could probably handle the power to the motor for a short while, but will likely fail down the road.  relay's are cheap anyways!
just get one rated to the amperage of the motor.  motor amps should be stamped somewhere on it.  get a simple 4 prong relay.  the two high amp lines - one goes to ground and one goes to power.  make sure not to switch them around from stock though otherwise you might reverse the flow like Vince said.  smaller two wires - one ground & one goes to the sensor.  if the sensor is a grounded sensor then you hook that up but give the relay 12v power at all times.  hope that makes sense!
Reply #17October 21, 2008, 04:04:19 pm
MouseGTD
  • 110
« Reply #17 on: October 21, 2008, 04:04:19 pm »
i'll have to take a look at the relays tomorrow, there all still plugged into the fuse box in the donor car. hopefully that last comment will make more sense when i can look at the relays and i am more sober lol.
thanks for all the help though every one 8)
