Author Topic: MK2 tranny into a MK1  (Read 19661 times)
Reply #15November 18, 2008, 11:43:34 pm
blkboostedtruck
  • 1535
« Reply #15 on: November 18, 2008, 11:43:34 pm »
josh,
is your car a gas or diesel?
if your in my area you can always look at mine!
Duane
P.S. you still want those snowflake rims?
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #16November 19, 2008, 12:49:28 pm
Josh
  • 54
« Reply #16 on: November 19, 2008, 12:49:28 pm »
It's a diesel, but I don't think it matters from what I've read of the tranny swap/A1 mounting and shifting hardware.  I'm going to have to hold off until I can find a complete linkage and tranny mount to cannibalize.  Calling junkyards today.
Rimwise, I could use some so I won't have to wrestle tires on and off rims pre and post winter.  I'm checking Venom next!
'84 Quantum sedan (oops, not '83!)
'83 Quantum wagon(ditto, not '82)
'82 Westfalia
'79 Rabbit
Mmmm.  Diesely.
Reply #17November 19, 2008, 01:00:10 pm
blkboostedtruck
  • 1535
« Reply #17 on: November 19, 2008, 01:00:10 pm »
Quote from: "Josh"
josh,
I'm a VENOM member and you asked about the rims over there!
you jump around too much! you looking for a TD motor for your MK1?
Duane
'66 variant 1500S
Reply #18November 19, 2008, 11:21:31 pm
Josh
  • 54
« Reply #18 on: November 19, 2008, 11:21:31 pm »
Already got a turbo motor for the '79 rabbit.  I've also got a turbo engine to rebuild for eventual installation into an '82 westy.
Know of a place called "sig's auto repair" on 13 n of the Dells?  I'm heading to his place tomorrow to scope out parts.
And I do jump around a bit, but it's only because I'm doing nothing but fixing my cars right now.
'82 Westfalia
'79 Rabbit
Mmmm.  Diesely.
Reply #19November 19, 2008, 11:51:15 pm
blkboostedtruck
  • 1535
« Reply #19 on: November 19, 2008, 11:51:15 pm »
no i'm not familiar with the dell's area!
i have 1.9TD's those would get a westy rollin!
Duane
'66 variant 1500S
Reply #20November 20, 2008, 04:47:42 pm
Josh
  • 54
« Reply #20 on: November 20, 2008, 04:47:42 pm »
Duane,
  I got some stuff today from Sig, but I might still need something or another.  I'd love a TD 1.9, but I can't afford it at the moment!
  -Josh
'82 Westfalia
'79 Rabbit
Mmmm.  Diesely.
Reply #21November 26, 2008, 11:10:27 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #21 on: November 26, 2008, 11:10:27 pm »
with regard to the linkages...
the 4 and 5 speed linkages are not so different - looking at your 4 speed linkage, the vertical rod that rotates about the north/south vehicle axis when moving the stick side to side - this vertical link is controls the across-the-box gear selection.
if you modify this link to be taller (cut and weld in another inch) you can use it no problems.
however, i found that the easiest (and coolest) way to make a 4 speed linkage into a 5-speed one is to flip the bell crank that is bolted to the final drive housing on the gearbox, upside down. this effectively gives you more throw from side to side, so you can easily select 5th gear. also makes for a nice tight feeling box... just be sure to adjust hte linkage splines so that you must still push down to engage reverse.
'91 Golf Cabrio 1.9TD
Reply #22November 27, 2008, 08:39:43 am
AdAm84
« Reply #22 on: November 27, 2008, 08:39:43 am »
Suprisingly that made sense :lol:
Reply #23November 27, 2008, 04:54:26 pm
gldgti
  • 488
« Reply #23 on: November 27, 2008, 04:54:26 pm »
Quote from: "gldgti"
just re-read my own post and thought i'd mention no sexual innuendo intended here :-D
