Author Topic: What is everyone running for EGTS?  (Read 8582 times)
Reply #30October 30, 2008, 09:12:37 am
« Reply #30 on: October 30, 2008, 09:12:37 am »
Quote from: "zozep"
So i've heard people say never to go above 1600... Is that never go above 1600 sustained? or never go above 1600 period? I'm pretty sure i've hit 1600, never for longer than a second though... but my jaunts to 100kmph WOT usually get me to 1450-1500 range... Whats safe?
Period!
1350 is suppose to be the max but hey it's your car.
Personally I've hit 1400 before but as I did I was off the smoke peddle. Don't need melted parts.
I've ran @ 1350 for a long 5 min pull up a hill as well but at that point I just didn't care. If it blew up I was going to leave the key in it on the side of the road.
Are you intercooled? That makes a bit of difference although it surely doesn't mean you can run @ 1600 deg.
I always try to back out long before 1300.
On my last engine I had hit 1600 a few times not paying attention and when I tore it down there was zero damage.
I'm NOT saying you will have the same luck.
Reply #31October 30, 2008, 09:14:37 am
zozep
  • 176
« Reply #31 on: October 30, 2008, 09:14:37 am »
1.6
Giles pump to 20lbs
BOV blocked, Wastegate bypassed to 15psi
arp headstuds
metal HG
stock everything else
no IC yet, thats next.
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M :(  DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
Reply #32October 30, 2008, 09:31:47 am
BioDieselVW
  • 93
« Reply #32 on: October 30, 2008, 09:31:47 am »
Zozep what are you running for a turbo? K14 or T3 or K24 ?
81 Caddy 1.6 TD
Callaway Intercooler
4in Exhaust Stack
Super Pump !
Reply #33October 30, 2008, 09:32:19 am
zozep
  • 176
« Reply #33 on: October 30, 2008, 09:32:19 am »
sorry K24
