Author Topic: Are My Glow Plugs Bad???  (Read 8253 times)
September 26, 2008, 08:43:28 am
tyluk
  • 22
« on: September 26, 2008, 08:43:28 am »
Hey everyone. So I'm wondering if I have glow plug issues. In the morning when I go to start my 83 quantum it has to crank for about 40 seconds before it actually continues to run on its own. This entire time there is blue smoke (unburned fuel?) billowing from the tailpipe. After this initial start it runs fine the rest of the day. Just began happening after a 2,000 mile journey. Just wondering if I need new glow plugs or if it is a relay or something. Thanks for the help.
1983 VW Quantum TD
2002 Ford Powerstroke
Reply #1September 26, 2008, 10:31:42 am
Possum79
  • 276
    • http://www.poscarclub.com
« Reply #1 on: September 26, 2008, 10:31:42 am »
1979 VW Rabbit Diesel L
Reply #2September 26, 2008, 10:34:22 am
Op-Ivy
  • 513
« Reply #2 on: September 26, 2008, 10:34:22 am »
Along with your other post it really does sound like your headgasket is done. If it takes that long to crank you may have poor compression and I would do a compression test if I were you.
Reply #3September 26, 2008, 11:02:24 am
tyluk
  • 22
« Reply #3 on: September 26, 2008, 11:02:24 am »
Where is the fuse for the glow plugs. I want to check the fuse. I've seen maybe on the firewall or under the dash. I don't see anything on my firewall when following the wire. It goes behind a bunch of junk and then i'm not sure if it heads into the firewall from there or towards the front of the car. I don't see anything that stands out.
1983 VW Quantum TD
Reply #4September 26, 2008, 11:03:49 am
« Reply #4 on: September 26, 2008, 11:03:49 am »
i think its a combination of valve sealing issues and bad glow plugs.  so bad compression & bad glows.  theres probably tons of life left in the motor though.. could even be rings.
whats the history on this motor? has it ever overheated when in your care?  any work done to it such as rebuild, new rings, etc??
Reply #5September 26, 2008, 11:41:16 am
tyluk
  • 22
« Reply #5 on: September 26, 2008, 11:41:16 am »
I don't know the history of the car. I bought it for $250 and drove it from NJ coast to Colorado (actually had a friend drive it). He said it never overheated for him. Once it got here started having the starting problem the next morning after arrival. Never had an issue in Jersey driving it there for a month. It basically started overnight. After the first start in the morning (40 -50 degrees) it runs and starts fine rest of the day.
1983 VW Quantum TD
Reply #6September 26, 2008, 12:30:50 pm
« Reply #6 on: September 26, 2008, 12:30:50 pm »
Quote from: "tyluk"
3 of my GP's burnt out on me at around the same time... car would not start  :(
Reply #7September 26, 2008, 03:15:47 pm
« Reply #7 on: September 26, 2008, 03:15:47 pm »
Pull them out and see, it's almost easier to pull the injectors to see then I think.
It's just easier with all the pipes etc out of the way.
First things first though. stick a test light on the bus bar and see if they are getting power, if not trace backwards till you find the problem, if there is power you will need to check each one..
Reply #8September 26, 2008, 04:26:31 pm
tyluk
  • 22
« Reply #8 on: September 26, 2008, 04:26:31 pm »
I do want to check the bus bar but where is it? I followed the glow plug wires into a bundle. Then they go back behind the brake master cylinder and then the coolant tank. From there I don't know where it goes. I thought the bus bar was on the firewall engine side but I can't find it. Is it inside the car near the fuses? Just give me hint. Thanks.
1983 VW Quantum TD
Reply #9September 26, 2008, 05:20:52 pm
« Reply #9 on: September 26, 2008, 05:20:52 pm »
The bus bar is the chunk of copper that connects all the glowplugs. Check for power there.
Reply #10September 26, 2008, 05:28:50 pm
burnt_servo
  • 278
« Reply #10 on: September 26, 2008, 05:28:50 pm »
find a amp meter  , and put in in the circuit that powers the glow plugs .
each glow plug draws 10 amps , 4 good glow plugs = 40 amps draw .....
3 good glow plugs = 30 amps draw .... and so forth
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #11September 26, 2008, 05:30:21 pm
« Reply #11 on: September 26, 2008, 05:30:21 pm »
that only works some times. On occasion they fail closed and will give a false reading
Reply #12September 26, 2008, 07:11:00 pm
tyluk
  • 22
« Reply #12 on: September 26, 2008, 07:11:00 pm »
Okay I appreciate all the great information but I'm still confused. I hope I'm not just an idiot but where is this bus bar (or chunk of copper)? In what general area should I be looking for it. Like I said I followed the wire from the GPs but didn't find anything on the engine side. Please give me a little more info if you can. Thanks.
1983 VW Quantum TD
Reply #13September 26, 2008, 07:22:48 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #13 on: September 26, 2008, 07:22:48 pm »
The "bus bar" is the flat copper bar that runs between the 4 glow plugs.  If you connect a test light to it, you can tell if you have power to the plugs, but that won't tell you if the plugs are ok.  Like jtanguay, I had 3 of 4 plugs fail - fine one day, next morning I couldn't start the car, and it was well above freezing out.  Replaced all 4 plugs, started like new.
Calvin
91 VW Golf 1.6NA 5spd
Reply #14September 26, 2008, 08:58:27 pm
tyluk
  • 22
« Reply #14 on: September 26, 2008, 08:58:27 pm »
Thank you so much for the clarification. I will try a test light on it tomorrow and let you know what I find. Like I said, working great one day and then the next won't start. Hopefully just something kinda simple.
1983 VW Quantum TD
