I hope you get your gauge figured out. Now, the real question- do you remember how to take the Giles pump back to the way Giles had it set up?
where would I hook up the ground at the gauge?
Quote from: theman53 on December 29, 2010, 08:31:09 amwhere would I hook up the ground at the gauge?I would start by grounding the gauge body. After a little research, I see that you cannot do much more than that.I wonder if you disconnect the gauge pigtail from the TC, what would the gauge do? If it does anything, the guage is BAD.I also see that westach suggests using NORMAL wire to extend the TC connections. See: http://www.acro.co.uk/html/Wiring/single_cht.htm
....and thank you for those numbers (17 and 19).
